Register to reply
Pendulum in water
by liz6
Tags: pendulum
Share this thread:
liz6
#1
Jun26-08, 10:05 AM
P: 1
first question: If a simple pendulum with a period of 1 second is set in motion on the moon,determine the new period of this pendulum.
second question: If a pendulum is made to swing in water,compare the time taken for this pendulum to come to a complete stop with the time taken by a pendulum swinging in air. Explain the difference.
2. Relevant equations
T=2(3.142)x(1/g)^1/2
3. The attempt at a solution
first question: the pendulum will swing forever on the moon because it is in a vacuum rite? but what does it mean by determine the new period?
the graph of period Ts against length for this question will be a straight line parallel to the x axis..?
second question: if a pendulum is made to swing in water, the resistance is higher compare to air rite? so the time taken for a pendulum to come to a complete stop is shorter compare to a pendulum swinging in the air...so the answer should be resistance?
but what is the graph of pendulum in water (period against length) would be like? is it a curve? have a lower gradient compare to the graph of pendulum in air?
i just want to make sure i did right for my coursework. thx for your help.
Phys.Org News Partner Science news on Phys.org
Wearable 4MM jetpack tested on speed, agility for runners (w/ Video)
How did evolution optimize circadian clocks?
Corn spots: Study finds important genes in defense response
nicksauce
#2
Jun26-08, 10:14 AM
Sci Advisor
HW Helper
nicksauce's Avatar
P: 1,275
The period depends on g. g is different on the moon. Hence the period will be different.
Register to reply
Related Discussions
Simple Pendulum Motion and Physical Pendulum Introductory Physics Homework 6
Which is better for measuring g? Bar Pendulum or Simple Pendulum? Advanced Physics Homework 4
Among Simple harmonic oscillation, simple pendulum and physical pendulum Introductory Physics Homework 10
HELP! relationship between rate of flow of water and height of water column Introductory Physics Homework 1
Basic question regarding triple point of water and physical properties of water Introductory Physics Homework 9
