Cylindrical Gaussian surface
by PhysicsRetard
Tags: cylindrical, gaussian, surface
PhysicsRetard
PhysicsRetard is offline
#1
Jun30-08, 10:56 PM
P: 1
A long cylindrical insulator has a uniformcharge density of 1.46uC/m3 and a radius of 6cm.
a-What is the electric field inside the insulator at a distance of 2cm and 12cm? Answer should be in N/C.
b-How much work must you do to bring a q=0.086uC test charge from 12cm to 2cm? Answer in J.
2. Relevant equations
I have started with p=Q/V. With V= [tex]\pi[/tex]r2h
3. The attempt at a solution...yet there is no h??
I know for r>R and r<R there are differences. I am lost. Please someone point me in the correct direction.
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
siddharth
siddharth is offline
#2
Jul1-08, 04:18 AM
HW Helper
PF Gold
siddharth's Avatar
P: 1,198
yet there is no h??
Well, it's there in the volume charge density that you've written, right? You have to construct an appropriate gaussian surface and apply Gauss's law to find the field. Can you proceed from here?
Irid
Irid is offline
#3
Jul2-08, 10:54 AM
P: 208
Step 1. Write down Gauss's law: [tex]\oint \mathbf{E}\cdot d\mathbf{a} = \frac{Q}{\varepsilon_0}[/tex]
Step 2. Determine the direction of electric field (radially outwards) and the Gaussian surface you're going to use (a cylindrical shell).
Step 3. Find the total charge enclosed within your Gaussian surface. Hint: [tex]Q = \rho V[/tex].
Step 4. Do the math to find the field. The height [tex]h[/tex] will cancel on both sides of Gauss's law equation.
For part b, integrate the electric field to get the potential.
Register to reply
Related Discussions
An Infinite Gaussian Surface? Classical Physics 1
Cant understand Gaussian surface Introductory Physics Homework 2
gaussian surface Introductory Physics Homework 4
Cylindrical Surface! Calculus 4
type(s) of charge distribution for spherical and cylindrical gaussian surfaces Introductory Physics Homework 1
