| Thread Closed |
Charge velocity and current density |
Share Thread | Thread Tools |
| Jul2-08, 11:59 AM | #1 |
Recognitions:
Current density is given in cylindrical coordinates as [tex]\vec{J} = -10^6z^{1.5} \hat{z} Am^{-2} \ \mbox{in the region} \ 0 \leq r \leq 20\mu m , \mbox{and for} \ r \geq 20 \mu m, \ \vec{J} = 0[/tex] If the volume charge density at z=0.15 m is -2000C/m^3, find the charge velocity there. 2. Relevant equations [tex]\nabla \cdot \vec{J} = -\frac{\partial \rho_v}{\partial t} [/tex] 3. The attempt at a solution Okay so this seems pretty straightforward. Given that J is only in the z-direction, then isn't it simply possible to find v_z by dividing J_z(0.15) by -2000 there? But this gives me 29 which isn't the answer. The answer is -2900. Another method I tried was solving for [tex]\rho_v[/tex] using the relevant equations. This gives me [tex]\rho_v = 1.5x10^6 \int \sqrt{z} dt = 1.5x10^6\sqrt{z}t + g(z)[/tex]. But how do I find what g(z) is? And I have to solve for t as well, since it's not stated what value of t I should evaluate the charge velocity for at z=0.15. |
| Jul2-08, 11:28 PM | #2 |
I don't think that answer is right. You are looking for dQ/dt and you know that [itex]\rho=Q/V[/tex] for a uniform charge, so then you can solve for dQ/dt from the continuity equation.
| Jul2-08, 11:36 PM | #3 |
Recognitions:
I don't think the charge is uniform. Why should it be?
| Jul2-08, 11:44 PM | #4 |
Oh, I guess I read it wrong. I suppose all the problem is really saying that only at the point z=.15 that it is uniform.
I mean, you have to know something about the charge density, or else you are shooting in the dark when it comes to finding the charge. |
| Jul3-08, 12:34 AM | #5 |
Recognitions:
The question is as stated. I didn't omit anything.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Charge velocity and current density
| relationship between current, drift velocity and thermal velocity | General Physics | 3 | ||
| A charge falls from infinity to within r of another charge, find velocity. | Introductory Physics Homework | 1 | ||
| Charge Density | Introductory Physics Homework | 13 | ||
| Finding diameter of a wire based on the current and current density. | Introductory Physics Homework | 1 | ||
| induced charge density by non-uniform dipole density in dielectric?! | Classical Physics | 1 | ||
