| Thread Closed |
electrons travel faster than the speed of light |
Share Thread | Thread Tools |
| Jul5-08, 05:35 PM | #1 |
Is it literally possible for them to be in two places at once?
Is this proven; How is this possible? I mean, sure they travel very, very fast. Even if they travel faster than the speed of light, it would appear so that they are, but nothing can travel at a speed that literally freezes time [only apparently]. I think this hints more towards electrons traveling though another spacial dimension than traveling though time. |
| Jul5-08, 06:38 PM | #2 |
An electron is described by its wave function. The wave function is used to find the probability density of the electron, that is, the probability of it being at locations within a certain space. This is because an electron is not a point in the classical sense. It doesn't have an exact location, but a probability density. This can explain why it can be in two places at once. This means that the speed the electron must travel to be in these two locations irrelevant.
| Jul5-08, 06:53 PM | #3 |
| Jul5-08, 07:33 PM | #4 |
Mentor
electrons travel faster than the speed of lightSo no, this isn't a "... sensationalism in the newspapers of the 1930s...." Zz. |
| Jul5-08, 07:34 PM | #5 |
...and I'm aware of the Uncertainty principle, but just because its location is in a designated area, specifically unknown, doesn't mean it's in all places at the same time in that area. |
| Jul5-08, 08:19 PM | #6 |
have you read the other replies? o.O
| Jul5-08, 09:53 PM | #7 |
I looked at the Philip Ball decoherence article, and I have studied Josephson junctions and SQUIDS, but I do not interpret quantum mechanics the way you do; it doesn't make sense. |
| Jul6-08, 04:15 AM | #8 |
Mentor
Whether it makes any sense or not, that is no longer physics but a matter of tastes. I find it to make perfect sense if one abandons the notion of a "classical particle" that has definite physical boundary. So what does not makes sense to you can make perfect sense to someone else. This is what I meant as simply a matter of tastes, so arguing about something based on one's sense doesn't mean anything. Besides, since when has making sense been infallible? Zz. |
| Jul6-08, 02:06 PM | #9 |
You and I, with the benefit of 70 years of physics since Schrodinger, know that superpositions become mixtures because of decoherence, and so the paradox is resolved. Schrodinger Cat-type experiments I followed the only link that leads to a freely accessible paper: Detection of a Schroedinger's Cat State in an rf-SQUID I read the entire paper, but did not find any evidence to support what you are calling the 'standard interpretation.' All of the wording in this paper is consistent with what I know about quantum mechanics, e.g. "Here we present the first experimental evidence that a superconducting quantum interference device (SQUID) can be put into a superposition of twomagnetic-flux states, one corresponding to a few micro-amperes of current flowing clockwise, the other cor- responding to the same amount of current flowing counterclockwise." Great, they put it in a superposition of both states, (A + B). This is very different from saying they put it in state A and state B simultaneously (again, I wouldn't even know how to interpret the latter within the formalism). Again from the article: "Such a superposition would manifest itself in an anticrossing, as illustrated in Figure 1b, where the energy level diagram of two levels of different flux states (labelled |0i and |1i) is shown in the neighbourhood in which they would become degenerate without coherent interaction (dashed lines). Coherent tunnelling lifts the degeneracy (solid lines) so that at the degeneracy point the energy eigenstates are close to 1 √2 (|0i + |1i) and 1 √2(|0i − |1i) , the symmetric and antisymmetric superpositions." In other words, they don't measure the superposition by measuring two currents going in opposite directions, they measure it directly by its properties as a superposition. psi = a*v1 + b*v2 then it does not make sense to say that the particle is also simultaneously in the states psi = v1 and psi = v2 Since all three of these states are totally distinct. We already know exactly what state the particle is in: psi = a*v1 + b*v2 And we can measure all the properties of the particle in this state. As for your abandoning the notion of a classical particle, this disagrees with the established standard interpretation in textbooks, e.g. "In QED, the electron is point-like particle." -- Griffiths, Introduction to Elementary Particles I also think the spread-out electron is untenable. In basic QM you could think of the electron as spread out in the form of the magnitude of its position space wave function, but what do you do in QFT? |
| Jul6-08, 02:52 PM | #10 |
Recognitions:
How would you compute the probability of a particle being in two places at the same time? Regards, Reilly |
| Jul6-08, 03:07 PM | #11 |
Mentor
http://www.sciam.com/article.cfm?id=schrdingers-squid http://physicsworld.com/cws/article/news/2815 http://physicsworld.com/cws/article/print/525 Zz. |
| Jul6-08, 03:14 PM | #12 |
Mentor
Look, I have ample problems with such interpretation and I can go on for pages on why I myself do not use such views. However, as I've mentioned in the previous post, it is THE prevailing view that when you have a "superposition of states", that ALL of those states are present simultaneously. The bell-type experiments is different from just a simple classical conservation of angular momentum case exactly because the superposition of the orthorgonal spin directions implies that the projection of the spin direction consists of all the possible spin states before measurement. Zz. |
| Jul6-08, 03:24 PM | #13 |
In the new experiments, an electric current stood in for the cat and flowed both ways around a loop at the same time. If you found a statement like this in a scientific article, or a graduate-level textbook, then I would be convinced. I too, however, have seen this kind of sensationalism in popularized articles, but I give infinitely more weight to the science I have learned from textbooks. |
| Jul6-08, 03:30 PM | #14 |
Mentor
Zz. |
| Jul6-08, 04:35 PM | #15 |
" What do you mean in terms of the formalism, 'has all the states'? " Now I see that you are contrasting the formalism with the interpretation, which I hope you will agree is not something that they do a very good job in the popularizations that you linked (which only matters because that general trend is responsible for the OP asking this question). In the future I will give a different response to the OP's question: |
| Jul6-08, 05:26 PM | #16 |
In case the OP as been left confused by that debate...
In orthodox QM we don't really talk about the electron "being" in two places at once. In fact, we don't really talk about it "being" anywhere. We say that it is described by a wave function [tex]\Psi[/tex], a mathematical function that we can coerce into telling us the probability that we will find the particle in a particular place, or moving in a particular direction. There are certain kinds of functions called eigenfunctions that describe the particle being in a state that is physically allowed. Arguably the most bizarre thing about quantum mechanics is that most of the time, a particle isn't described by an eigenfunction, but by a linear combination of eigenfunctions; its wavefunction is that function you obtain by adding one eigenfunction to another, each function being multiplied by appropriate numbers so that you don't get probabilities greater than one. A particle described by such a linear combination of "allowed" states is said to be in a "superposition of states", and this is the origin of loose phrases such as "is in two places at once". That much isn't really controversial (which you may find suprising!). What is controversial is whether or not nature really behaves in the way our maths seems to describe when we aren't looking; whether an electron really exists as some fuzzy, smeared-out field that decides to adopt definite values only when we decide to look for it. The part to which there are the most serious objections is the transition between a superposition of states and the particle we actually measure, a process known as the collapse of the wavefunction. Some people think it is physically real, but argue over what constitutes a measurement- some say it has to be carried out by a conscious observer, wheras some say any thermodynamically irreversible interaction with the environment will do. Some, however deny it, and instead claim that rather than the superposition of the particle collapsing, the observer instead is in a superposition of having measured all the possible values! This is the origin of talk you may have heard of the "many-worlds" interpretation. In one "world" the particle goes through one slit, in another it goes through the other, and the poor observer is split into two duplicates of himself, each identical in every detail except that memory corresponding to whether he believes the photon went through the left slit or the right one. This may all seem deeply, deeply wierd. It is. Unfortunately (or interestingly, depending on your point of view) the experimental facts are so wierd as to necessitate a wierd explanation! |
| Jul7-08, 05:40 AM | #17 |
Another possible interpretation is that the electron "is not" here, or there, or in both places, before detecting it: it "is" where and when you detect it. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: electrons travel faster than the speed of light
| which force seperates the electrons and nucleus and causes the electrons to orbit??? | General Physics | 14 | ||
| where do the electrons go?? | Quantum Physics | 10 | ||
| Electrons | Introductory Physics Homework | 4 | ||
| Electrons | Chemistry | 4 | ||
