Proving a Subgroup of a Solvable Group is Solvable
  • Context: Graduate
  • Thread starter Thread starter samkolb
    Group Subgroup
The discussion revolves around the proof that a subgroup of a solvable group is itself solvable. Participants explore definitions of solvable groups, the construction of composition series, and the properties of factor groups, with a focus on whether the distinct groups formed from the intersection of a subgroup with a composition series yield a composition series for the subgroup.
  • One participant states that a subgroup of a solvable group must have a composition series where each factor group is abelian, referencing the Fraleigh Abstract Algebra book.
  • Another participant suggests that the definitions of solvable groups in different texts are equivalent, noting that factor groups exist only for normal subgroups.
  • A participant expresses difficulty in showing that the distinct groups from the intersection of the subgroup and the composition series form a composition series for the subgroup.
  • There is a suggestion that the requirement for the factor groups to be simple may be a misunderstanding, with a focus instead on them being abelian.
  • Another participant argues that it is sufficient to show that the intersection groups are abelian, and questions the necessity of showing simplicity.
  • Further comments indicate that a composition series is not strictly necessary, and any subnormal series with abelian quotients could suffice, with suggestions on how to construct such a series.
  • One participant notes that the only simple abelian groups are cyclic groups of prime order, which could influence the structure of the subgroup.
Participants exhibit disagreement regarding the necessity of showing that the factor groups are simple versus abelian. There is no consensus on the best approach to proving the subgroup is solvable, with multiple perspectives on the definitions and requirements involved.
Limitations include the dependence on definitions of solvable groups and the potential need to refine the series used to establish the properties of the subgroup. The discussion highlights unresolved mathematical steps in proving the subgroup's solvability.
samkolb
I'm supposed to show that a subgroup of a solvable group is solvable.
(I am using the Fraleigh Abstract Algebra book and the given definition of a solvable group is a group which has a COMPOSITION series in which each of the factor groups is abelian. In other books I have looked at a solvable group is defined as one which has a SUBNORMAL series in which all the factor groups are abelian.)
Let K be a subgroup of a solvable group G. Let
{e}=Ho<H1<...<Hn=G be a composition series for G in which all the factor groups are abelian.
I showed that the distinct groups from among (K & Hi) (&= set intersection)
form a subnormal series for K.
Then I used the second isomorphism to show that (K & Hi)/(K & Hi-1) is isomprphic to Hi-1(K & Hi)/Hi-1.
I then showed that Hi-1(K & Hi) is a subgroup of Hi. Since Hi/Hi-1 is abelian, Hi-1(K & Hi)/Hi-1 is abelian, and so (K & Hi)/(K & Hi-1) is abelain.
What I can't show is that the distinct groups among (K & Hi) from a composition series for K. That is, I can't show that (K & Hi)/(K & Hi-1) is simple.
Please help!
These are the same: factor groups only exist for normal subgroups.
please could you tex this clearly so people can understand what you mean?
Surely you mean abelian, not simple?
Thank you for responding to my question.
As I said in the preface to my question, I need to find a composition series for K in which each of the factor groups is abelian. So I need each of the factor groups (K & Hi)/(K & Hi-1) to be both abelian and simple.
Why do you need to show that? [itex]K\cap H_{i}/K\cap H_{i-1}[/itex] is isomorphic to a subgroup of [itex]H_i/H_{i-1}[/itex], so it is abelian, and this is enough to show that K is simple.
Actually, if K is a strict subgroup of G, you will have [itex]H_i\cap K=H_{i-1}\cap K[/itex] for at least one i. So, [itex]K\cap H_i[/itex] will not be a composition series -- you would have to remove some of them from the series.
I've got 2 further comments on your question.
First, you don't need to use a composition series. Any subnormal series for which the quotients [itex]H_i/H_{i-1}[/itex] are Abelian will do. Then, you can eliminate any [itex]H_i[/itex] for which [itex]H_i=H_{i-1}[/itex]. Then, if any of the quotients are not simple you can enlarge the series, until you reach a maximum one. This will be a composition series and the quotients will still be abelian.
Second, the only simple abelian groups are the cyclic groups of prime order. Any subgroup will be either the trivial group, or the whole group, so still simple. So, the way you have set up the problem it will be the case that you get a composition series once you eliminate any terms with [itex]K\cap H_i=K\cap H_{i-1}[/itex].
gel:
Thank you for your comments. They were very helpful.
  • · Replies 26 ·
