| Thread Closed |
Finding the Magnitude and Direction of Force one with the Resultant Given |
Share Thread | Thread Tools |
| Jul6-08, 05:24 PM | #1 |
| Jul6-08, 05:41 PM | #2 |
![]() Yes … split the force F1 into Fx and Fy … then do x and y separately … finally combine Fx and Fy to give you F1 and theta.
| Jul6-08, 07:08 PM | #3 |
Hi,
Thanks for helping me, but one more question, my Fx and Fy for F1 is unkown as shown in the diagram that i have posted earlier, so how do i go about solving for the magnitude of F1 and the direction of F1. Sorry for the trouble.... thanks Nacha |
| Jul7-08, 06:35 AM | #4 |
Finding the Magnitude and Direction of Force one with the Resultant GivenHave you got Fx and Fy yet? You can get them from the diagram. Then use Pythagoras, and tangents.
| Aug3-10, 10:40 AM | #5 |
can anyone explain how to solve this problem in complete details? i don't understand the explanations. i have the same problem too.
| Aug3-10, 11:01 AM | #6 |
hi sandra! welcome to pf!
![]() you need to get all the y-components adding to 800, and all the x-components adding to zero that will give you two equations involving two unknowns (F1 and θ), which should enable you to find the unknowns what do you get? |
| Aug3-10, 11:11 AM | #7 |
owhh.. how about to solve this question:
determine the magnitude and direction of P so that the resultant of P and the 900N force is a vertical force of 2700N directed downward. is it using the same method also? it's almost the same right? |
| Aug3-10, 11:14 AM | #8 |
right!
| Aug3-10, 11:19 AM | #9 |
thanks so much tiny-tim! i'm doing my engineering mechanics tutorial problems right now.. if i have any problem again, i'll ask your help later.. ;)
| Aug3-10, 11:20 AM | #10 |
err... do you online often? then, i'll know when can i ask for your help..
| Aug3-10, 11:24 AM | #11 |
sandra, just post a new thread any time
…somewhere in the world, there'll be someone awake and logged in ready to help, whatever time it is
| Aug3-10, 11:30 AM | #12 |
okie! will do..
| Aug14-10, 07:00 AM | #13 |
i got a similar problem but i dont have a resultant force :\ not sure on how to solve ive found theata using a parallelogram
theata is the one between the X axis and F1 |
| Aug14-10, 07:24 AM | #14 |
Hi Zlash! Welcome to PF!
![]() (have a theta: θ )Sorry, I dont understand the question … you have three forces (100N 350N and R), and also a line called X at 30º … if X is equivalent to F1 in Nacha's question, then changing the magnitude of X will give different directions for the resultant R (but a unique magnitude for each direction) … if neither the magnitude nor the direction of R is given, I don't see how you can answer the question
| Aug14-10, 07:49 AM | #15 |
in the quiz im doing it doesnt say anything about a resultant but im assuming we have to use the one given in the text book. so the resultant measured from the positive X' -the line- is 600N i found θ as 60. θ being between F1 and the X axis( not x' ) im not sure how i can work through forces based on different axis kinda messes me up =/ im trying it now |
| Oct13-10, 06:31 AM | #16 |
hi all
∑F x= 400cos30 – 600 cos36.87 + F1 sinØ =0 ∑F y= 400sin30 – 600sin36.87 + F1 cosØ =0 R=√(〖fx〗^2+〖fy〗^2 ) 800=√((〖298.35+f1sinØ)〗^2+〖(560+f1 cosØ)〗^2 ) As we see ; we have two equation and two unknown so we can get the magnitude and direction of f1 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding the Magnitude and Direction of Force one with the Resultant Given
| Finding the direction of the resultant vector of three vectors? | Introductory Physics Homework | 10 | ||
| resultant force direction | Introductory Physics Homework | 3 | ||
| Finding resultant force | Introductory Physics Homework | 9 | ||
| Finding the resultant force | Introductory Physics Homework | 7 | ||
| Magnitude and Direction, Gravitational force Q | Introductory Physics Homework | 2 | ||
