| Thread Closed |
Flow rate |
Share Thread | Thread Tools |
| Jul7-08, 04:08 AM | #1 |
Flow rate
A large tank at first has 50 gallons of a solution that is holding 10 lbs. of a chemical. Water is going through at a constant rate, and the mixture is going out at a constant rate. What will be the flow rate if 2 lbs. remains after 20 mins?
I assume it's a differential eqns. problem. I think I should define x(t) as amount of chemical, so dx/dt = - x(t)/50 but I'm not really sure. Can somebody walk me through this? |
| Jul7-08, 04:34 AM | #2 |
Well the water and chemical is decreasing at a constant rate so i doubt you should use differential equations.
Here is what i think - 8lb of chemical in 20 mins = 0.4lb/min 50 gallons for 10 lb of chemical = 5gal/lb gallons/min = 0.4 * 5 = 2 gal/min |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Flow rate
| ppm and flow rate | General Physics | 4 | ||
| Flow Rate | Mechanical Engineering | 6 | ||
| Another flow rate question | General Engineering | 6 | ||
| flow rate | Introductory Physics Homework | 2 | ||
| Rate of Flow Q | Introductory Physics Homework | 1 | ||
