Installing Single Drain Sink Systems | Plumbing Advice
  • Thread starter Thread starter james.parera
    Systems
The discussion focuses on the installation of a single drain sink system, specifically addressing the plumbing requirements for connecting a garbage disposal and dishwasher. To properly install these components, the dishwasher's exit must connect to the garbage disposal, ensuring a high loop to prevent siphoning. The outlet from the garbage disposal should then connect to a P Trap before leading to the main drain, maintaining a downward slope. Participants also recommend consulting local hardware stores and DIY resources for additional guidance.
  • Understanding of plumbing systems and drainage
  • Familiarity with PVC piping installation
  • Knowledge of garbage disposal and dishwasher connections
  • Basic plumbing tools and safety practices
  • Research proper installation techniques for garbage disposals in single drain systems
  • Learn about the use of P Traps in plumbing
  • Explore DIY resources for plumbing projects
  • Investigate local plumbing codes and regulations
This discussion is beneficial for plumbers, DIY enthusiasts, and homeowners looking to install or modify single drain sink systems, particularly those integrating dishwashers and garbage disposals.
james.parera
Hi All
one of my cline has recently changed his double drain sink with a single drain sink.
I now need to redo all the plumbing to allow for single drain usage.
I am having a hard time trying to find what is the proper way to install the disposal and dishwasher to a single drain,
and at the same time what is the proper layout of the PVC piping.
we will highly appreciate your feed back.
Thanks in advance.
By disposal do you mean a garbage disposal? If so; connect the exit from dishwasher to the disposal, making sure it makes a loop higher than entry point, otherwise it will siphon back into dishwasher. Then connect the outlet from garbage disposal to a P Trap and then to main drain, ensuring a downward slope.
If there is no garbage disposal, then there is a special fitting that you can use to connect dishwasher to plumbing.
I did mine this winter and I just set it up the way it was suppose to be, and then took digital pictures of it to the local hardware store and they told me what I needed and how to do it. Also there are sites like DIY that have information.
Hope this helps.
james.parera said:
Hi All
Thanks in advance.
Most dishwashers have a hose that tees directly into the single drain, which is the same drain line the disposal is connected to. Just make sure the hose has a loop high enough to prevent backflow into the dishwasher.
CS
  • · Replies 31 ·
  • · Replies 39 ·
17K
19K
