Low Pass Filtering - Generate a Slowly Changing Signal in Matlab
  • Context: MATLAB
  • Thread starter Thread starter sarahpaninsky
The discussion revolves around generating a slowly changing signal in MATLAB by filtering white noise using a low-pass filter characterized by an alpha function. Participants explore the implementation of this filter, its parameters, and the resulting signal characteristics, focusing on both theoretical and practical aspects of signal processing.
  • One participant seeks assistance in generating a slowly changing signal by filtering white noise with an alpha function, suggesting it serves as a low-pass filter response.
  • Another participant requests to see the original MATLAB code to provide better assistance and questions whether the alpha function represents a step or impulse response.
  • A participant modifies the original code to improve performance, suggesting adjustments to the time units and the length of the impulse response to optimize the filtering process.
  • Concerns are raised about the time units used in the code, with suggestions to reduce the number of points in the sequence to improve efficiency.
  • One participant expresses dissatisfaction with the results, indicating a need for the output to match a specific figure from a referenced scientific paper, highlighting issues with amplitude and fluctuations.
  • Another participant discusses the implications of using incorrect tau values, predicting the cutoff frequency of the filter and its relation to the desired output characteristics.
  • Technical details are provided regarding the frequency response of the filter, including the relationship between the time constant and cutoff frequency.
  • Participants discuss the normalization of the filter gain and the potential issues with aliasing in the digital implementation of the filter.
  • A later reply corrects a typo in the frequency response equation, clarifying the mathematical representation of the filter's behavior.
  • One participant attempts to approximate the desired results by adjusting the original code, including changes to the tau value and the normalization of the impulse response.
Participants express various viewpoints regarding the implementation of the filter and the expected characteristics of the output signal. There is no consensus on the best approach, and multiple competing views remain regarding the appropriate parameters and methods for achieving the desired signal characteristics.
Limitations include potential misunderstandings of the time constant tau, discrepancies in expected versus actual output characteristics, and unresolved issues related to the normalization of the filter response. The discussion also highlights the differences between analog and digital filter implementations.
sarahpaninsky
Hi,
I want to generate a slowly changing signal (1 second duruation).
For this, I must filter white noise with a filter which is characterized by an alpha function as below
alpha(t)= t*exp(-t/tau) ( I think function is low-pass filter response)
where tau=3 ms. I couldn't achive this in matlab. Can anyone help me for this?
Regards
Can you show us your work? We can help you better if we see your approach and your Matlab code.
By the way, is your alpha a step response (probably) or an impulse response?
clear
figure
tau=3;
noise=8+7*randn(1,1e5);
t=[0:0.01:1e3];
y=conv(noise,t.*exp(-t./tau));
subplot(3,1,1)
title('Gaussian Noise')
plot(noise)
subplot(3,1,2)
plot(y)
title('Filtered Noise')
My code is like above.
As I said before the filtered signal must be slowly changing, is like a stimulus not actually like noise to a biological neuron. Please modify my code
Be careful of your time units. You specified tau=3, implying that your waveforms are sampled at 1000 Hz. Then each point in your sequence is separated by 1 ms. Your impulse response dies to essentially zero after 30 ms, so there's no need to include 1e5 points!
Below I relabeled your t as n to make the point that this is the index of a sampled data sequence, and reduced the length of the impulse response h to 30 points. I also reduced the input sequence noise to 10,000 points so it runs faster, but this is not important.
clear
tau=3;
noise=randn(1,1e4);
n=[0:30];
h = n.*exp(-n/tau);
y=conv(noise,h);
figure
subplot(3,1,1)
plot(noise)
subplot(3,1,2)
plot(y)
This does low-pass filter your noise. You can display the frequency response of your filter and output with the following commands:
Fs = 1000;
Hs=spectrum.periodogram
figure
psd(Hs,h,'Fs',Fs)
title('Filter Response')
figure
psd(Hs,y,'Fs',Fs)
title('Output Spectrum')
Fs above is the sampling frequency, 1000 Hz in this case. Notice that your cutoff frequency (-3 dB) is about 35 Hz. You probably studied the relation between time constant and cutoff frequency fc; what is it? See if you can adjust tau to get fc=1 Hz. You'll have to readjust the sampling frequency to match your new tau...
clear
tau=3;
noise=randn(1,1e4);
n=[0:30];
h = n.*exp(-n/tau);
y=conv(noise,h);
figure
subplot(3,1,1)
plot(noise)
subplot(3,1,2)
plot(y)
Fs = 1000;
figure
psd(Hs,h,'Fs',Fs)
figure
psd(Hs,y,'Fs',Fs)
Thanks for your interest Marcusl,
But the results are not sufficent.
I want to show you my work, I want to reproduce the low-pass gaussian white noise stimuli as in the image I attached. if you look at it, you may understand my problem with the code. What could I do ? Filtering is Okey but the the code is fails for amplitude and fluctuating?
Sorry, I thought this was a homework assignment. I'll take a close look at this tonight.
What are the spikes they refer to? Are they individual channel responses? What is the significance of jitter? (I work in radar, not membranes...)
Would you post the paper, or link to it?
thx
my e-mail is "opamp67@hotmail.com", if you send a blank mail, I will send you immediately. Because I cannot attach the paper as the file size limit of the forum.
This is an scientifistic paper on Neuron modelling in biomedical disciplinary. in the paper Figure1 is important for me, especially top two figures which are related to low-pass gaussian noise. My final code is below to produce the signal Fgi1B (top trace)
clear
figure
tau=3;
noise=8+7*randn(1,5e4);
t=[0:0.01:499.99];
h=t.*exp(-t/tau);
y1=(fft(noise));
y2=(fft(h));
y3=(ifft(y1.*y2));
plot(t,y3);
axis([0 500 -2 11])
I can take a few moments at lunch to make the following comments:
1) You've used tau = 3 sec in your code instead of 3 msec. This will produce a very low frequency output (filter cutoff of 0.05 Hz, according to calc below).
2) You can predict the cutoff (-3dB or half power) frequency of the analog alpha filter as follows. You've specified an impulse response
[tex]\alpha(t)=t\exp{(-t/\tau)}[/tex] which has Laplace transform
[tex]F(s)=\frac{1}{(s+1/\tau)^2}[/tex].
Evaluating [tex]s=i\omega+\sigma[/tex] on the frequency (imaginary) axis
gives the frequency response as
[tex]|F(\omega)|=\frac{1}{|\omega+1/\tau|^2}[/tex].
This is a two pole lowpass filter with cutoff frequency
[tex]f_c=\frac{1}{2\pi\tau}[/tex].
The point is, [tex]\tau=3 ms[/tex] gives a filter rolloff of [tex]f_c=53 Hz[/tex].This is roughly consistent with the waveform in Fig. 1B, and is not consistent with your statement that the waveform should change on the order of seconds.
3) You can see from the expression for F that the filter gain is not normalized to one at zero frequency. Dividing by tau^2 gives proper DC normalization
[tex]\alpha(t)=\frac{t}{\tau^2}\exp{(-t/\tau)}[/tex].
4) In general, sampling the impulse response of an analog filter the way you've done it here is not the optimal way to implement a digital filter. One problem is that analog and digital cutoff frequencies don't match. If you look at the power spectral density of h using the psd commands I gave above, you'll see that the -3dB frequency response of the digital filter using tau=3 ms is around 35Hz instead of the 53 Hz calculated for the analog filter. A sampled impulse response implementation also aliases, so F(w) doesn't roll off towards zero as expected but flattens out. Finally, the DC normalization is thrown off. I assume that is why Fig. 1 shows a mean of about 4, even though the input had a mean of 8 that should be unchanged by the lowpass.
I'm not sure whether these considerations are important to your paper and work, but at least you have an appreciation of what this system is doing from the standpoint of digital signal processing.
Sorry, there's a typo in the frequency response--there should be an i in front of omega:
[tex]|F(\omega)|=\frac{1}{|i\omega+1/\tau|^2}[/tex]
Of course this simplifies to
[tex]|F(\omega)|=\frac{1}{\omega^2+1/\tau^2}[/tex]
Ok, the "scientifistic" paper you sent contains no information on the signal processing used within, beyond that mentioned in the Figure attachment above. The fact that the signal mean values in Fig. 1 A,B differ from input to output is strange. We'll take the "filter method" in Fig. 1 at face value, however, lacking any other information. Changing the OP's code as follows at least approximates their results:
clear
tau=3e-3;
noise=8+7*randn(1,1e4);
t=[0:0.001:0.03];
h = t .* exp(-t./tau) ;
y=conv(noise,h/sum(h));
figure
subplot(3,1,1)
plot(noise)
axis([500 1000 0 15])
subplot(3,1,2)
plot(y)
figure
plot(h)
title('Filter Impulse Response')
One-half second of signal is plotted, as in the paper. The filter is normalized ad hoc by dividing by the sum of the impulse response.
clear
tau=3e-3;
t=[0:0.001:0.03];
figure
subplot(3,1,1)
plot(noise)
subplot(3,1,2)
plot(y)
figure
plot(h)
That is GREAT Marcusl. I am glad to you. Everything is OK now. Thanks your kind interest.
26K
  • · Replies 16 ·
10K
