What is the electron configuration of Ni2+?
  • Thread starter risky
  • Tags
    Chemistry
In summary, the electron configuration of Ni2+ is [Ar] 3d8. This is determined by the fact that nickel is in the period after argon, so the octet configuration is already accounted for with the symbol [Ar]. From there, it is determined that there are 8 electrons remaining, which can be filled in the 3d subshell. This follows the Aufbau principle and Madelung rule, which state that orbitals are filled in order of increasing n+l value, with exceptions for orbitals with the same n+l value.
risky
a. [Ar] 3d6 4s2
b. [Ar] 3d7 4s1
c. [Ar] 3d8
d. [Ar] 3d8 4s2
e. [Ar] 3d8 4s1
Alright, Nickle is in the period after Argon, that's why you don't have to state the configuration of argon and you can give the symbol: [Ar] This just signifies the octet configuration (8 electrons in valence shell). Then, as you notice, Ni2+ has a number of 28-2= 26.
Ar has an atomic number of 18.
26-18=8.
So you have 8 electrons left. so you can cancel out options d and e.
The d subshell has 5 orbitals. The principal quantum number of the d subshell is 3 in this case. 3 is lower than 4, thus, theoretically, you will fill in the lower quantum number first. There are special cases which do not exhibit this though.
And that's why you'll fill in these 8 electrons into the orbitals in 3d. Making it:
[Ar]3d8
Hope it helps. You can ask me again if you don't get this.
Please check Aufbau principle and Madelung rule. 3d is filled before 4p and 5s. Just looking at the principal quantum number is not enough.
Madelung rule states that orbitals are filled in the order given by sum n+l, if for two orbitals n+l is identical the one with lower n is filled first.
There are exceptions though.
Yeah sorry for missing that. >< needa go review my chem again.
Thanks
1. What is chemistry?
Chemistry is the scientific study of matter, its properties, and the changes it undergoes. It is often called the "central science" because it connects and overlaps with other branches of science, such as biology, physics, and geology.
2. Why is chemistry important?
Chemistry is important because it helps us understand the world around us and how things work. It also plays a crucial role in industries such as medicine, agriculture, and technology, and helps us develop new materials and processes for everyday use.
3. What are some common chemistry problems?
Some common chemistry problems include balancing chemical equations, calculating molar mass and percent composition, and identifying types of chemical reactions. Other problems may involve stoichiometry, gas laws, and acid-base chemistry.
4. How do I approach solving chemistry problems?
The best way to approach solving chemistry problems is to break them down into smaller, more manageable steps. Start by identifying the given information and what you are trying to find. Then, use the appropriate formulas and concepts to solve the problem, making sure to show all your work and units. Finally, check your answer to ensure it makes sense and is consistent with the given information.
5. What resources are available for help with chemistry problems?
There are many resources available for help with chemistry problems, including textbooks, online tutorials, and study guides. Your teacher or professor is also a valuable resource and can provide additional guidance and clarification. Additionally, forming a study group with peers can be beneficial in working through difficult problems together.
11K
  • Atomic and Condensed Matter
