Momentum and velocity/position vectors
  • Thread starter Thread starter deborahlane
    Momentum Vectors
The problem involves two particles colliding on a smooth horizontal table, where one particle has a mass of m and the other has a mass of 3m. The velocities of the particles are given, and the task is to analyze their motion before and after the collision, including determining the velocity of the coalesced particle, energy lost, and the position vectors of the particles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the conservation of momentum and kinetic energy to analyze the collision. There are attempts to derive position vectors from velocity vectors, with questions about the integration process and the implications of negative time. Some participants express uncertainty about how to approach the calculations for position vectors and the center of mass.
Participants are actively engaging with the problem, offering suggestions and clarifications. There is recognition of the need to consider the center of mass and the implications of the collision on the system's momentum and energy. Some confusion remains regarding the transition from velocity to position vectors, particularly in the context of negative time.
Participants note the importance of correctly applying the principles of momentum and energy conservation, as well as the need to clarify the setup for calculating position vectors before the collision.
deborahlane
I have two particles moving on a smooth horizontal table. The first, A, has mass m and the second, B, has mass 3m. A has velocity 2i + 3j and B has velocity 6i - 5j. They collide at the origin at t=0 and coalesce.
I have to 1) determine the velocity of the coalesced particle after the collision; 2) determine the amount of energy lost in the collision; 3) find expressions for rA(t) and rB(t) at time t<0; 4) find the position vector of the centre of mass of the system before the collision; 5) determine the velocity of the centre of mass; 6) find the position vector of the coalesced particles at time t>0 after the collision; and 7) comment on the answers to parts 3)-6)
I've used the following: 1) Total linear momentum of system P=mv and found P of A is 2mi + 3mj and P of B is 18mi - 15mj, so using the Principle of conservation of momentum, I found v of coalesced particle to be 5i - 3j
2) kinetic energy=1/2mmodv2 and KE before impact is 98m and after is 68m, so loss is 30 joules.
4) rG=[tex]\Sigma[/tex]miri all divided by total mass...when I finally find the position vectors!
5) Velocity of the centre of mass=total linear momentum of the system...I think.
6) With position vectors for A and B, I'm not sure what to do here: add them, since the particles coalesce?
3) My problem is from 3) onwards. I'm pretty sure I can figure out the rest of it once I have 3). I can't work out how to get from the velocity vectors to position vectors. I thought of integrating and using t=0 r=0 to find a particular solution, but that seems to just leave me with rA(t)=2ti + 3tj and rB(t)=6ti - 5tj, which just doesn't seem to make sense.
Welcome to PF deborahlane and thanks for taking the time to lay out your problem properly.
deborahlane said:
1) Total linear momentum of system P=mv and found P of A is 2mi + 3mj and P of B is 18mi + 15mj, so using the Principle of conservation of momentum, I found v of coalesced particle to be 5i - 3j
Correct, just a small typo highlighted in red.
Looks good to me.
Okay for number three:
deborahlane said:
3) 'm pretty sure I can figure out the rest of it once I have 3). I can't work out how to get from the velocity vectors to position vectors. I thought of integrating and using t=0 r=0 to find a particular solution, but that seems to just leave me with rA(t)=2ti + 3tj and rB(t)=6ti - 5tj, which just doesn't seem to make sense.
You're almost correct here. Notice that you are dealing with the case when t<0, i.e. negative time.
Again looks good.
Don't forget to divide by the total mass!
Consider the centre of mass of the system, what can you say about the velocity of the COM before and after the collision?
Thanks, Hootenanny. Your suggestions have been very helpful! Sadly, though, I'm still lost on part 3)! I'll give it some more thought and see what more advice others can give, and what I can work out from your help!
Scrap my previous comment regarding question (3), your answer is entirely correct! Sorry for the confusion.
Great! :)
  • · Replies 30 ·
  • · Replies 20 ·
