Can f(n) equal f(x) in the sum of digits equation?
  • Context: Graduate
  • Thread starter Thread starter dapet
    Sum Sum of digits
The discussion revolves around the "sum of digits" equation, specifically exploring whether for a natural number n, there exists a natural parameter p such that the equation f(npx) = f(x) holds true for some natural number x that does not contain the digit "9." The scope includes theoretical exploration and mathematical reasoning.
  • One participant introduces the problem of finding a natural parameter p such that f(npx) = f(x) for some x without the digit "9."
  • Another participant asks about the specific case where n consists of repeated digits of "1" (e.g., 1111...1).
  • It is clarified that the discussion is in base ten.
  • A participant references a theorem from Acta Arithmetica, suggesting that if 30 does not divide n, the equation holds true and that there are infinitely many choices for x from the set {1, 11, 111, 1111,...}.
  • Further clarification is provided regarding two cases based on the divisibility of n by 30, though the details remain incomplete.
Participants express differing views on the conditions under which the equation holds, particularly regarding the divisibility of n by 30. The discussion remains unresolved with multiple competing perspectives on the problem.
Some assumptions about the nature of n and the properties of the sum of digits function are not fully articulated. The implications of the conditions related to divisibility by 30 are also not completely explored.
dapet
Let f(n) denote the sum of (all) digits of natural number n. Prove that for each natural n we can choose convenient value of natural parameter p such that the equation f(npx)=f(x) has solution in natural numbers x that doesn't contain any "9" in its notation.
Does anybody have any idea? I don't... but I hope that you do... Actually I can solve a lot of special cases on a lot of pages... but I can't solve it generally. Is there any trick or only hard work? Thank you.
Can you handle the case where n=1111...1 ?
one presumes you mean in base ten as well.
Yes, you're right... in base ten.
If 30 doesn't divide n, the result is true (see Acta Arithmetica 81; Mauduit and Scharkozy's article on sum of digits, theorem 2).
You can impose lot's of conditions on x (the only thing you really need is that you have an infintly choice on it) as x is in the set {1,11,111,1111,...}
If 30 divide n, the result is true too, but i don't have reference (it's only a special technical case).
Sorry i have done a small confusion : the 2 cases are
* If 30 is prime with n, then, ...
* If 30 and n have a commun divisor, then ...
