Volume of Rotated Region: y=x and y=x^2, about x-axis and y=2
The volume of the solid formed by rotating the region R, enclosed by the curves y=x and y=x^2, about the x-axis is calculated to be 2π/15. In contrast, when the same region is rotated about the line y=2, the volume increases to 8π/15. This discrepancy arises because the radius of rotation differs between the two axes, as explained by Pappus' theorem. The distance from the rotational axis to the farthest point of the solid varies significantly, leading to different volumes for each rotation.
  • Understanding of integral calculus, specifically volume of solids of revolution
  • Familiarity with the curves y=x and y=x^2
  • Knowledge of Pappus' centroid theorem
  • Experience with calculating volumes using the disk and washer methods
  • Study the application of Pappus' theorem in calculating volumes of solids of revolution
  • Practice calculating volumes using the disk method for various functions
  • Explore the washer method for finding volumes between two curves
  • Investigate the effects of changing the axis of rotation on volume calculations
Students studying calculus, particularly those focusing on volumes of solids of revolution, as well as educators seeking to clarify concepts related to rotational volumes and Pappus' theorem.
fk378
(a)The region R enclosed by the curves y=x and y=x^2 is rotated about the x-axis. Find the volume of the resulting solid.
(b)Find the volume of the solid in part (a) obtained by rotation the region about y=2.
I solved the (a) integral and got 2(pi)/15, which is the right answer. I thought that (b) would give the same answer, since I'm just rotating it about a different line. But my answer (which is right) is 8pi/15. Can anyone explain why the volume would be different? It's the same solid, just rotated about different lines, right?
They are not 'the same solid'. The radius of rotation in the two different cases is different. Look up Pappus' theorem.
Let's take the example of making a donut in a similar manner. Take an oval centered on the origin where the longest radius is in the y-direction. Make a solid by rotating this region about the axis x=10 where 10 > the longer radius of the oval. This will make a donut and you could find the volume, but if you were to instead make a donut by rotating around y=10, it would not have the same volume as the solid made by rotating around x=10. I would expect that the y=10 solid would have a larger volume since it will have a greater distance from the center to the edge of the solid.
In your case, you're making some weird solids. and the distance from the rotational axis to farthest out point is not even the same in both cases. Around the x-axis, the farthest out point from the axis is x=1 so a magnitude of 1 away. For the y=2 axis, the farthest point away from it is x=0 for a magnitude of 2 away. I hope this helps you visualize this better.
  • · Replies 21 ·
