What Determines Earth's Yearly Cycle?
  • Context: High School
  • Thread starter Thread starter biophysics
    Cycle
The discussion centers on the forces and mechanisms that determine Earth's yearly cycle, including its orbit around the sun, rotation, axial tilt, and the duration of a year. Participants explore various aspects of these phenomena, including gravitational forces, tangential velocities, and the historical context of Earth's formation.
  • Some participants suggest that the Earth is in a constant state of free fall towards the sun, with its tangential velocity preventing it from falling directly into the sun.
  • Others argue that no force is needed to maintain the Earth's tangential velocity, as per Newton's first law, and question what initiated this velocity.
  • There is a discussion about the Earth's axial tilt and its implications for seasons, with some participants noting that the tilt does not precess significantly over a year but rather over thousands of years.
  • One participant raises the question of what caused the Earth's rotational velocity and whether it is decreasing due to interactions with space debris.
  • Another participant mentions that the formation of the solar system and the circularization of Earth's orbit are still open to debate, with various hypotheses proposed regarding the initial conditions of Earth's formation.
  • Precession of the Earth's tilt is introduced as a concept, likening it to the behavior of a spinning top.
  • Some participants emphasize that once the solar system was set into motion, no additional forces are required to maintain the current motions of celestial bodies.
Participants express multiple competing views regarding the forces and historical processes that led to Earth's current motion and characteristics. The discussion remains unresolved, with various hypotheses and questions posed without consensus.
Limitations include the lack of consensus on the initial conditions of Earth's formation, the specific causes of its rotational and tangential velocities, and the mechanisms behind its axial tilt and precession.
biophysics
1) the Earth moves around the sun. What is the force causing this movement around the sun? I know that there is a gravitational force pulling it inward, but what force keeps it from falling toward the sun?
2) The Earth is constantly spinning. This causes the day/night that we see. What is the force causing this revolution?
3) The Earth tilts on its axis about 23 degrees. This causes the seasons. What is the force causing this tilt?
4) Why does it take 365 days for the tilt in question 3 to complete 1 period
Please tell which question you are answering. thanks
Astronomy news on Phys.org
The Earth is falling toward the sun - it just always misses! That's what an orbit is.
Another way to describe an orbit is that the tangential velocity is high enough that the Earth accelerates toward the sun without ever getting closer to it.
Or, if you prefer, an orbit is what happens when the acceleration due to gravity is balanced by the "ficticious" centrifugal force.
By Newton's first law and/or conservation of energy, a force is not required to keep a moving object moving.
Again, no force.
Force causes acceleration. If there is no acceleration, there is no need for a force.
The tilt does not precess in 365 days - it takes thousands of years. What happens in 365 days is that the Earth orbits the sun. Draw yourself a diagram if you can't see why the seasons happen with a fixed tilt.
thanks for your response:
For the orbit around the sun
1) The Earth has a tangential velocity which is constant. Since there is no acceleration, no force is needed to maintain this tangential velocity. However what brought the Earth to this tangential velocity? Also is the tangential velocity decreasing as the Earth does not travel in a vaccum(stuff runs into the earth)?
2) What caused the rotational velocity of the Earth (the one that causes night/day) to begin?
3) Thanks for explaining the tilt concept. Is it known what causes this tilt, or it's movement over thousands of years
thanks
#1. The stuff Earth runs into is insignificant compared to Earth's mass. Even if it weren't, it can hit Earth from the front or the rear, or above, or below, resulting in no significant bias.
#1 & 2. These are open to debate. The formation of the solar system is not completely understood. Earth's tangental velocity is the perfect speed for a (or an almost) circular orbit. How Earth's orbit circularized is open for debate. Perhaps it formed in a circular orbit, or perhaps it originally had a good deal of eccentricity and its orbit circularized later due to its interactions with solar system debris, or to a lesser degree, with the tides it pulls on the Sun (which is probably easily-computable, allowing it to be ruled out).
#2. If Earth had no rotational velocity, that would more-require an explanation than Earth having rotational velocity. During formation, Earth was getting bashed left and right, up and down, by objects ranging in size from microscopic to objects rivaling Earth's mass. It would be a weird lottery-style chance if after all that, Earth's spin ended up perfectly stationary. The bias, as demonstated by most other planets in the solar system, is a counter-clockwise (as viewed from above), prograde (same as its orbital direction) rotation. This was probably imparted by the momentum of the stuff that bashed together to form the Earth.
#3. Again, a tile of 0.0000 degrees would more-require the explanation. Because Earth is not perfectly spherical, this gives a handle for other solar systems to tourque it around over long time scales, so the tilt precesses.
The main reason things in the Solar System move as they do is as a result of the formation of the system itself.
Please see http://en.wikipedia.org/wiki/Solar_nebula#Formation_of_planets
or refer to any decent introductory astronomy textbook.
Please note, as mentioned above, once this was all set into motion no forces are required to keep it going.
  • · Replies 31 ·
