Thread Closed
electric ceiling fan
Share Thread Thread Tools
Jul21-08, 04:41 AM   #1
An electric ceiling fan is rotating about a fixed axis with an initial angular velocity of 0.290 rev/s. The angular acceleration is 0.888 rev/s^2. Its blades form a circle of diameter 0.740 m.
Through how many revolutions has the blade turned in the time interval 0.208 s from Part A?
2. Relevant equations
theta (t) = theta (0) + w (0) t+ .5 at^2
3. The attempt at a solution
ngular velocity = .475 rev/ sec
.475 rev/s * .208 s = .0988 rev
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jul21-08, 09:17 AM   #2
Recognitions:
Homework Helper Homework Help
Hi teenholiday,
Quote by teenholiday View Post
Why didn't you use the equation you have listed under "Relevant equations" in your post?
(In your work, you found the final velocity, and then you found the number of revolutions it would have taken if it had been rotating at that final velocity the entire time; but I don't think that is what's happening in this problem.)
Jul21-08, 10:36 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
How did you arrive at this? You were told that the initial angular velocity was .290 rev/s and the angular velocity is NOT a constant!
That is assuming a constant angular velocity which is not true. I'm with alphysicist: why not use the formula by have under "relevant equations"?
You could also use a different method: in general, with constant acceleration, the average velocity is just the arithmetic average of the initial velocity and the final velocity. You are told that the initial velocity is .475 rev/sec. It it accelerates at 0.888 rev per second per second for .208 seconds, how much will the angular velocity increase by? So what will be the final angular velocity? And then what is the average velocity? Using that average angular velocity, how many revolutions will be made in .208 seconds? You might try using both methods and see if you get the same answer.
Jul21-08, 02:53 PM   #4
thanks for the alternative method.
i had tried using the relevant equation, but i must have been tired or something, because i kept on getting the wrong answer.
i got it now though. thanks.
Thread Closed
Thread Tools
Similar Threads for: electric ceiling fan
Thread Forum Replies
About Ceiling Calculus & Beyond Homework 0
Inequality involving ceiling Precalculus Mathematics Homework 1
reversible ceiling fan Computing & Technology 6
A mass hanging from the ceiling Engineering, Comp Sci, & Technology Homework 3
physics of a reversible ceiling fan General Discussion 17
