Thread Closed
Ideal Gas Law and Isobaric Processes
Share Thread Thread Tools
Jul21-08, 09:33 PM   #1
Hi,
So let's take the standard example of a gas in a container with a piston at the top. Charles' Law states that at constant pressure, an increase in temperature (kinetic energy of gas molecules) will increase the volume. This makes sense both conceptually and mathematically (per PV = nRT). However, in an isobaric process (pressure is constant again), the kinetic energy of the gas molecules is what is moving the piston so it must have lost some energy in doing so. Therefore, although initially Esystem = q that was added, it's net energy change would be Esystem = q - Pext*V.
So this is my problem, wouldn't this isobaric process be inconsistent with the ideal gas law? That is, using strictly the ideal gas law, woudn't the ending temperature not take into account the work done on the piston? Or are we assuming in using the ideal gas law that the work to keep the pressure constant is from an external source?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jul21-08, 10:32 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by nothing123 View Post
Hi,
Thanks.
You're mixing two different concepts. The ideal gas equation of state shows the relationship between P, V and T at a specified state. An isobaric process (or any process) shows how a substance changed from an initial state to a final state.
Does that help?
CS
Jul21-08, 10:45 PM   #3
Could you clarify exactly what you mean by states? I mean, since the heat added only changes the kinetic energy of the system (which is proportional to temperature), wouldn't we be able to find the same change in temperature whether we used Echange = q + w or whether we used T = PV/nR?
Thanks for your help so far.
Jul21-08, 11:30 PM   #4
Recognitions:
By state I mean a set of properties that completely describe the condition of the system. If the system is not changing, it is in equilibrium. If the system undergoes a process, something has changed the system and it is now in an alternate state. The ideal gas law describes the state of an ideal gas. If the ideal gas undergoes a process, the process path from state 1 to state 2 will describe how the system changed. Once at state 2 the ideal gas relation can describe the system at that state.
Also, the properties of an ideal gas at two different states for a fixed mass are related by the ideal gas law as well and is called the combined gas law IIRC. However, you would need to know some of the properties at both states in order to solve for the unknown. Hence, the process path must be known.
BTW,
[tex] \Delta U = Q_{net,in} - W_{net,out} [/tex]
Shows that for a closed system the internal energy of a substance decreases if it does work on it's surrounds. Hence it's temperature would decrease. So for an isobaric process like you described, the change in internal energy and thus temperature would depend on how much heat was added, and how much work was done by the piston on its surroundings.
This is typically stated using the enthalpy for simplicity:
[tex]Q - W_{other} = H_2 - H_1[/tex]
Does that help?
CS
Jul21-08, 11:45 PM   #5
Thank you very much. Clearing up that state definition really helped.
Jul22-08, 11:58 AM   #6
Recognitions:
Homework Helper Homework Help
T = PV/nR does not tell you the what P is and what V is. It only tells you what their product is. If T increases, PV must increase at the same rate. If it happens at constant volume, there is no work done by the gas. If it occurs at constant pressure, work is done so the heat flow is greater. PV=nRT always applies, as does dQ = dU + PdV.
AM
Thread Closed
Thread Tools
Similar Threads for: Ideal Gas Law and Isobaric Processes
Thread Forum Replies
Isobaric Expansion Introductory Physics Homework 5
Isobaric process Introductory Physics Homework 2
Adiabatic Processes and Ideal Gases Introductory Physics Homework 19
isobaric expansion Introductory Physics Homework 1
Isobaric question Introductory Physics Homework 3
