Dirac delta approximation - need an outline of a simple and routine proof
The discussion focuses on proving the identity involving the Dirac delta approximation using a function \(\theta\) that decays faster than any polynomial. The goal is to demonstrate that for a continuous, smooth, and bounded function \(f\), the limit \(\lim_{a \rightarrow 0}\int_{-\infty}^{+\infty} f(x) \frac{1}{a}\theta\left(\frac{x}{a}\right) dx = K f(0)\) holds true. Key observations include the approximation of the integral of \(\theta\) over the entire real line by its integral over a finite interval and the continuity of \(f\) at zero. The proof does not require complete rigor, making it suitable for applications in physics.
  • Understanding of distributions and the Dirac delta function
  • Familiarity with limits and integral calculus
  • Knowledge of properties of smooth and bounded functions
  • Concept of rapid decay in functions
  • Study the properties of the Dirac delta function in distribution theory
  • Learn about the method of approximating functions using mollifiers
  • Explore the implications of continuity in limits and integrals
  • Investigate the role of rapid decay in function behavior at infinity
Mathematicians, physicists, and students engaged in advanced calculus or analysis, particularly those working with distributions and approximations in theoretical contexts.
hooker27
Hi, I need your help with a very standard proof, I'll be happy if you give me some detailed outline - the necessary steps I must follow with some extra clues so that I'm not lost the moment I start - and I'll hopefully finish it myself. I am disappointed that I can't proof this all by myself, but I really need to move on with my work so any help here will be appreciated.
Let [tex]\theta[/tex] be a function that decays faster than any polynomial, is smooth or whatever else is required. Let
[tex]\int_{-\infty}^{\infty} \theta = K[/tex]
I want to show, that for all reasonable [tex]f[/tex] (continuous, smooth, bounded, ... again - whatever is required) the following identity holds
[tex]\lim_{a \rightarrow 0}\int_{-\infty}^{+\infty} f(x) \frac{1}{a}\theta\left(\frac{x}{a}\right) dx = K f(0)[/tex]
In other words - the limit
[tex]\lim_{a \rightarrow 0} \frac{1}{a}\theta\left(\frac{x}{a}\right)[/tex]
is a multiple of Dirac delta, in the sense of distributions. The proof needs not to be 100% precise, even 80% precise, I need it for some little physics paper I write and physicists are seldom 100% precise (in math, anyway), but I need something a little more rigorous than "Let's assume [tex]\theta[/tex] is rectengular..." for which the proof is way too easy.
I appreciate any help, thanks in advance. This is no hw, if it's any important.
What lines of attack have you tried on this? It's hard to give helpful hints without knowing where you're at on the problem!
Anyways, two high-level observations that are almost surely useful to the proof (or at least to the devising of a line of attack) are
[tex]\int_{-\infty}^{+\infty} \theta \approx \int_{-H}^{+H} \theta[/tex]
and
[tex]f(\epsilon) \approx f(0),[/itex]<br /> <br /> capturing the notions that [itex]\theta[/itex] is rapidly decaying and that <i>f</i> is continuous at <i>0</i>, respectively.<br /> <br /> (<i>H</i> is a 'large' positive number, [itex]\epsilon[/itex] is a 'small' positive number)<br /> <br /> <br /> (I use the integral expressing that the tails are irrelevant, rather than something more direct like [itex]\theta(\pm H) \approx 0[/itex], because the integral actually appears in the data you've given)[/tex]
Are you sure you don't want [itex]\frac{1}{a}\theta (a x)[/itex]?
  • · Replies 25 ·
11K
10K
  • · Replies 29 ·
