How Do You Calculate Concentrations Without the Ka Value?
  • Thread starter Thread starter dnt
To calculate the concentration of all species in a 0.240 M C6H5NH3Cl solution, one must understand the dissociation reaction involving aniline hydrochloride, which is a salt of a weak base and a strong acid. The Ka value for the dissociation is not provided, prompting users to look it up, as it is essential for determining the concentrations of the species involved. The Kb value of aniline or the Ka value of protonated aniline can be utilized interchangeably due to their conjugate relationship. Tools such as the pH calculator BATE and Buffer Maker are recommended for these calculations.
  • Understanding of weak acids and bases, specifically aniline and its conjugate acid.
  • Knowledge of acid-base dissociation constants (Ka and Kb).
  • Familiarity with buffer solutions and their calculations.
  • Proficiency in using pH calculation tools like BATE and Buffer Maker.
  • Research the Kb value of aniline to facilitate calculations involving its conjugate acid.
  • Learn how to use the pH calculator BATE for accurate concentration determinations.
  • Explore the concept of buffer solutions and their role in pH stability.
  • Investigate the relationship between Ka and Kb for conjugate acid-base pairs.
Chemistry students, laboratory technicians, and anyone involved in acid-base chemistry or buffer solution preparation will benefit from this discussion.
dnt
question states: Calculate the concentration of all species in a 0.240 M C6H5NH3Cl solution.
first of all how do i know what the reaction is? secondly to i need to know the Ka value for the dIssaciation for this - why isn't it given?
Aniline hydrochloride - salt of a weak base and a strong acid. You will need Kb of aniline or Ka of protonated aniline (hint: these are conjugated acid and base, so if you know one, you can calculate the other).
Most likely Ka was not given to force you to look it up.
pH calculator BATE & Buffer Maker - the ultimate buffer calculator
  • · Replies 48 ·
9K
  • · Replies 16 ·
