electric field inside cavity
by i_island0
Tags: cavity, electric, field, inside
i_island0
i_island0 is offline
#1
Jul27-08, 12:15 PM
P: 121
The figure shows a cuboidal shaped conductor inside which there is an ellipsoidal cavity. The center of the cavity is at the center of the cuboid.
Link to figure: http://www.picscrazy.com/view/1qtB9
A charge qo is kept at the center of the cavity. I am showing two positions 'A' and 'B'. MY question is in which location, among 'A' and 'B', (on the inner surface of cavity) the surface charge density will be more. At 'A' or at 'B'.
I have two arguments to present:
(i) The system will try to minimize its energy - so, in that case the surface charge density at B will be less than surface charge density at A. Or to say in other words, since the radius of curvature at B is more, so the charge at B will be less. A is sharper than B so charge density at A will be more.
(ii) now charge qo is closer to B than A. So shouldn't i conclude that charge density at B will be more than charge density at A. Since charge qo is closer to B, so electric field lines will be more dense near B, so the charge density at B will be more.
I m not sure which of the arguments is correct. And why? can anyone help me in this. ??
Phys.Org News Partner Physics news on Phys.org
Better thermal-imaging lens from waste sulfur
Scientists observe quantum superconductor-metal transition and superconducting glass
New technique detects microscopic diabetes-related eye damage
clem
clem is offline
#2
Jul27-08, 04:16 PM
Sci Advisor
P: 1,250
B has the higher surface charge density.
Your argument (i) is wrong because the curvature wrt the conductor is actually negative for this geometry.
For a charge outside a conducting ellipsoid, the SCD would be greater at the end.
Manchot
Manchot is offline
#3
Jul27-08, 05:04 PM
P: 728
(ii) is correct. More rigorously, the conductor will be at a constant potential, and so the line integrals of the electric field from q0 to B and from q0 to A must be the same. Therefore, the magnitude of the field at B must be higher than A.
i_island0
#4
Jul27-08, 11:02 PM
P: 121
wow, sometimes the explanations are so simple, but yet so tough to think
thanx to both of you
Register to reply
Related Discussions
Electric field in an empty cavity Advanced Physics Homework 3
Electric field in metal cavity General Physics 6
Field inside a cavity inside a conductor Introductory Physics Homework 3
electric field is zero at center of cavity? Classical Physics 2
If ia charge is placed inside a conductor, is the electric field inside zero? Introductory Physics Homework 1
