Thread Closed
Analytic continuation
Share Thread Thread Tools
Jul28-08, 05:00 AM   #1
I have a very simple question but one I've not been able to answer by
looking in the usual sources.
If I have a function f defined by a power series limited by a pole at a
say, and I analytically continue the function with another suitably
located series then....
is it possible for the region of validity of second series to include
the pole of the first series and hence eliminate the pole?
mikej
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jul28-08, 05:00 AM   #2
>mikej
Stated simply: the radius of convergence of a power series is the the
distance to the nearest singularity. You can redefine your origins to
construct a power series that valid for an arbitrary region, but its
radius of convergence is still constrained by the origin's distance to
the nearest singularity. The answer to your question is no.
Jul29-08, 05:00 AM   #3
> mikej
You need to use a rational approximant (Pade) instead of a series
approximant (Taylor).
Jul29-08, 05:00 AM   #4
No, that's impossible. That would imply that analytic continuation is
not unique. The only wiggle room is in the multi-sheetedness of the
function's Riemann surface. That is, the two expansions will approach
the same point of the complex plane along different sheets of the
Riemann surface. But I don't think that's what you had in mind.
Hope this helps.
Igor
================== RFC 822 Headers ==================
Return-Path: nobody@mailman2.ucar.edu
Received: from mailman2.ucar.edu (192.43.244.82)
by elijah.robots.multivax.de (V5.3-18G, OpenVMS V7.3 VAX);
Sun, 27 Jul 2008 21:02:57 +0200
Received: from mailman2.ucar.edu (mailman2.ucar.edu [127.0.0.1])
by mailman.ucar.edu (Postfix) with ESMTP id 089E95C400F
for <helbig@astro.multivax.de>; Sun, 27 Jul 2008 13:03:45 -0600 (MDT)
Received: (from nobody@localhost)
by mailman2.ucar.edu (8.13.1/8.13.1/Submit) id m6RJ3ijB024228
for helbig@astro.multivax.de; Sun, 27 Jul 2008 13:03:44 -0600
X-Original-To: physics-research@mailman.ucar.edu
Received: from nscan1.ucar.edu (nscan1.ucar.edu [128.117.64.191])
by mailman.ucar.edu (Postfix) with ESMTP id A57155C4006
for <physics-research@mailman.ucar.edu>; Sun, 27 Jul 2008 13:03:44 -0600 (MDT)
Received: from localhost (localhost.localdomain [127.0.0.1])
by nscan1.ucar.edu (Postfix) with ESMTP id 814227FC0E2
for <physics-research@ucar.edu>; Sun, 27 Jul 2008 13:03:44 -0600 (MDT)
Received: from nscan1.ucar.edu ([127.0.0.1])
by localhost (nscan1.ucar.edu [127.0.0.1]) (amavisd-new, port 10024)
with ESMTP id 26221-09 for <physics-research@ucar.edu>;
Sun, 27 Jul 2008 13:03:42 -0600 (MDT)
X-SMTP-Auth: no
Received: from moderators.individual.net (moderators.individual.net [130.133.4.7])
by nscan1.ucar.edu (Postfix) with ESMTP id 7E5177FC0E1
for <physics-research@ncar.ucar.edu>; Sun, 27 Jul 2008 13:03:42 -0600 (MDT)
Received: from proxy.google.com ([64.233.187.4])
by moderators.individual.net (Exim 4.69)
for sci-physics-research@moderators.isc.org with esmtp
(envelope-from <news@google.com>)
id <1KNBWv-0007TE-Jp>; Sun, 27 Jul 2008 21:03:41 +0200
Received: from AR020007
by proxy.google.com with ESMTP id m6RJ3fOs017056
for <sci-physics-research@moderators.isc.org>; Sun, 27 Jul 2008 12:03:41 -0700
Received: (from news@localhost)
by Google Production id m6RJ3eCJ027935
for sci-physics-research@moderators.isc.org; Sun, 27 Jul 2008 12:03:40 -0700
To: sci-physics-research@moderators.isc.org
Path: f36g2000hsa.googlegroups.com!not-for-mail
Date: Sun, 27 Jul 2008 12:03:40 -0700 (PDT)
NNTP-Posting-Host: 207.112.103.224
Mime-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 7bit
X-Trace: posting.google.com 1217185420 27932 127.0.0.1 (27 Jul 2008 19:03:40 GMT)
X-Complaints-To: groups-abuse@google.com
NNTP-Posting-Date: Sun, 27 Jul 2008 19:03:40 +0000 (UTC)
Injection-Info: f36g2000hsa.googlegroups.com; posting-host=207.112.103.224;
posting-account=eYQbUAkAAACwOlkS00T33jJSkpXVdh8D
User-Agent: G2/1.0
X-HTTP-UserAgent: Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.8.1.13)
Gecko/20080313 Iceape/1.1.9 (Debian-1.1.9-5) Mnenhy/0.7.4.0,gzip(gfe),gzip(gfe)
X-Virus-Scanned: amavisd-new at ucar.edu
Jul30-08, 05:00 AM   #5
> Hope this helps.
> Igor
Yes, at least it has helped me work out what it is that is troubling me
about the idea.
If you think of an analytic function as and object that exists
independently of its representation by a formula then the pole of a
given series expansion might be regarded as a flaw in the representation
- as in the case of a co-ordinate chart that doesn't cover a particular
point say.
If this is the case then the pole isn't part of the analytic function,
its an anomaly of the formula representing it.
If on the other hand the pole is part of the function and this causes
the function representing it to fail then clearly another representation
must also have a pole in the same place.
Continuity arguments suggest to me that the pole is part of the function
and must exist in any representation.
However this is slightly worrying to me in that the information within a
disk of convergence contains enough information to construct the
(analytic) function anywhere in the complex plane - including all of its
poles(?) mikej
Jul31-08, 05:00 AM   #6
> > Hope this helps.
> > Igor
> about the idea.
> point say.
> poles(?) mikej
Perhaps it helps you to understand that analytic functions
satisfy a system of differential equations.
(Cauchy-Riemann)
In the case of differential equations it's not surprising at all
that you may find the function 'everywhere'
from its values in a small region.
Jan
Aug1-08, 05:00 AM   #7
> (Cauchy-Riemann)
> Jan
Yes indeed - but including points where the function doesn't have a
derivative?!
I can see that there is no problem for a smooth analytic function with
derivatives of all order defined at a point even being extended to the
entire real line (or in the complex case plane) but
the idea that the derivatives also encode the poles of a function is
more worrying.
mikej
Aug3-08, 05:00 AM   #8
>> (Cauchy-Riemann)
>> Jan
>derivative?!
>more worrying.
>mikej
As they should be. Any analytic continuation must dance around these
singular points. That's why your power series can't be simply defined
everywhere.[1]
But using the distance to the nearest singularity to define the power
series' domain of convergence is still very useful, if not of immediate
interest regarding your problem. That's how the radius of convergence of
the power-series representations of elliptic functions is determined.
I've used it to find the radius of convergence of some pretty nasty
power-series myself.[2]
Finally, you may want to look at some texts on elliptic functions. This
type of problem has been dealt with quite successfully there. I,
personally, have found some very useful hints in solving problems inside
these books.
[1] As I recall the original post asked about finding a valid power
series representation.
[2] "Particle trajectories in 1/r fields", M. Arnow, J. Math Physics, V.
21, 1980
Aug3-08, 05:00 AM   #9
> > (Cauchy-Riemann)
> > Jan
> derivative?!
You can find the function wherever it is well-defined.
It is worse than that however, for analytic functions may have natural
boundaries, beyond which they cannot be continued.
One derivative will do.
If differentiable, it will be infinitely differentiable.
> but
> more worrying.
Why? The poles are just as much part of the function
as the regular parts.
You can't have an analytic function that behaves as 1/z
away from z=0 without having the pole at z=0
To clarify: my remark about satisfying the differential equations
was meant to relativize the importance of the process of continuation
by successive power serie expansions.
These may be seen as just a convenient way
of solving the Cauchy-Riemann equations.
Best,
Jan
Aug3-08, 05:10 AM   #10
>> derivative?!
Although not really connected to my initial question - can you give me
an example of a "natural boundary"?
>> more worrying.
Put like that - yes I can't see what I'm worried about
- 1/z behaviour away from the pole is perfectly reasonable and, as you
say implies the pole's existence at z=0.
(I guess my problem is due to not really taking on board the difference
between a Taylor and a Laurent series.)
I think I now understand - analytic continuation can't "remove" poles as
information about them is contained in any region that you are using to
continue the function. They really are part of the function and not any
particular formula that you are using to encode the function.
Many thanks
mikej
Aug4-08, 05:00 AM   #11
> everywhere.[1]
Yes I agree but my question was really about the poles that were far
enough away not to effect the power series in use - i.e. well outside
the radius of convergence.
What I really wanted to know is whether or not these are "real" and part
of the function - and the answer is obviously (now it has been explained
to me) yes.
Thanks
mikej
Aug4-08, 05:00 AM   #12
A class of examples are so-called lacunary series. Take
f(z) = sum_{n=0 to oo} z^(2^n) = z + z^2 + z^4 + z^8 + ...
The radius of convergence of this series is equal to 1. However,
unlike a series with a pole at distance 1 from the origin, this series
diverges as every point on the boundary of the unit disc. In fact,
every point with |z|=1 is an essential singularity.
The proof is sketched in the Wikipedia page discussion the class of
lacunary series:
http://en.wikipedia.org/wiki/Lacunary_function
Hope this helps.
Igor
Aug5-08, 05:00 AM   #13
> lacunary series:
> Hope this helps.
> Igor
Oh yes it does... it helps to know that such terrible things exist :-)
mikej
Aug5-08, 05:00 AM   #14
You could multiply your existing series by a factor which eliminates
the pole you don't like; and try to do (express) everything with the
new pole-free series instead. I can't guarantee this will help whatever
you in want to do, however.
Dr. Paul Kinsler
Blackett Laboratory (PHOT) (ph) +44-20-759-47734 (fax) 47714
Imperial College London, Dr.Paul.Kinsler@physics.org
SW7 2AZ, United Kingdom. http://www.qols.ph.ic.ac.uk/~kinsle/
Aug6-08, 05:00 AM   #15
Yes this is what prompted the question - I'm looking at various methods
of regularisation and suddenly realised that, despite thinking that I
did understand analytic continuation, I really didn't....
I think I do now so thanks everyone.
And I might have some questions on regularisation when I had time to
think about it a bit more.
mikej
Aug8-08, 05:00 AM   #16
You do analytic regularization by setting up everything in such a way
that all your expressions are analytic functions in some variable.
(warning: this step is in no way unique, except by definition)
Then you expand everything in a Laurent series around the pole,
and discard all pole parts.
The result is arbitrary by a 'finite regularization',
that is, an additive constant.
(as are all other regularization methods,
unless you fix that constant by definition)
The simplest way to see that this must be the case
is by noting that instead of Regu (f(z))
you may also take 1/g(z) Regu (g(z)f(z)),
with g(z) some arbitrary entire function.
The linear part of g(z) and the pole part of f(z)
multiply to the arbitrary extra constant.
Best,
Jan
Thread Closed
Thread Tools
Similar Threads for: Analytic continuation
Thread Forum Replies
analytic continuation Advanced Physics Homework 1
Analytic Calculus & Beyond Homework 5
Convergence question on analytic continuation of Zeta fcn Calculus 3
GR and analytic continuation Differential Geometry 18
what is analytic continuation? Calculus 3
