How Do Response Factors for Na and K Compare Using Li as an Internal Standard?
  • Thread starter Thread starter ssb
    Factors Response
The discussion focuses on determining the response factors for sodium (Na) and potassium (K) using lithium (Li) as an internal standard. The concentration ratio provided is 5.0 ppm for both Na and K, with Li at 500 ppm. The calculated response factors are 13.5 for Na and 17.7 for K, derived from the equations Ax/x = F(As/s). The calculations appear correct based on the provided data, confirming the methodology used in the analysis.
  • Understanding of absorption spectroscopy principles
  • Familiarity with response factor calculations
  • Knowledge of concentration ratios in analytical chemistry
  • Basic proficiency in chromatography techniques
  • Review the principles of absorption spectroscopy and its applications
  • Study the calculation of response factors in analytical chemistry
  • Learn about the use of internal standards in quantitative analysis
  • Explore chromatography techniques and their role in separation science
Chemistry students, analytical chemists, and laboratory technicians involved in quantitative analysis and spectroscopy techniques.
ssb
Determine the response factors for both Na and K with the Li internal standard
Concentration Ratio
Na : K : Li (in ppm)
5.0 : 5.0: 500
Signal Ratio
Na : K : Li (relative units)
4.9 : 6.4: 36.2
Ax/x = F(As/s)
Ax = absorption signal of analyte
x = concentration of analyte
F = response factor
As = absorption signal of standard
s = concentration of standard
Calculation for Na
(4.9)/(5.0) = F [(36.2)/(500)]
F = 13.5
Calculation for K
(6.4)/(5.0) = F [(36.2)/(500)]
F = 17.7
Seems simple enough right? So I was hoping that someone would be able to tell me if this is correct or incorrect because I have a funny feeling I did something strange (problem was too easy).
It would be helpful to have more information on the equation and the reference, but based on the limited information provided, Ax/x = F(As/s), it would appear that the answers given are correct.
Is the problem/question based on an example of chromatography and spectroscopy?
  • · Replies 89 ·
39K
