Prevent Overheating of Laptop After Watching DVDs
  • Thread starter Thread starter Lonewolf
    Laptop
The discussion revolves around methods to prevent laptop overheating after watching DVDs. Participants explore various strategies for improving laptop cooling and managing heat during use, particularly in relation to airflow and surface placement.
  • One participant suggests ensuring good ventilation and possibly using small fans that attach to expansion card ports.
  • Another participant explains that laptops typically use two airflow methods for cooling, emphasizing the importance of placing the laptop on a solid surface to maintain airflow.
  • A participant humorously notes that faster laptops may run hotter, proposing that users consider cooler-running processors to mitigate overheating.
  • Common sense advice is offered, including avoiding insulating surfaces and using a cooling pad to maintain airflow under the laptop.
Participants generally agree on the importance of proper ventilation and surface placement for cooling, but there are multiple competing views on the best methods and considerations for preventing overheating.
Some suggestions depend on specific laptop designs and user environments, and there may be unresolved assumptions regarding the effectiveness of proposed solutions.
Lonewolf
I recently watched a DVD on my laptop, after which, my laptop became seriously over-heated. It wouldn't work properly for about an hour. Is there any (sensible) method of avoiding this, apart from not watching DVDs?
Computer science news on Phys.org
You could try giving it good ventilation, mounting it so air can flow under the base could help, just a guess seeing as I don't own a laptop. I think you can also buy small fans that attach to the expansion card ports. :)
Laptops generally use two methods of airflow to cool themselves. The first method (and superior, imo) is the intake on the side, exhaust on the back. The second method involves intake from the bottom/exhaust on side/back.
A good plan is to make sure you set it on a solid surface, so it's rubber "feet" will keep enough space between it and the surface. A wood surface is the best, just keep it off metal and other good conductors of heat.
Funny how laptops never work that well on their namesake...laps
Yeah, and don't the faster ones tend to also run hotter as well? So if you want a real screamer then perhaps it will also be a real scorcher too.
I would look for the coolest running processor around to avoid heating the darn thing to the point where you can't even keep it on your lap. Well, coolest running within reason that is, haha, my old compaq 386/25 is WAY COOL . How about a VIA gigapro type processor, any thoughts?
The best advice is use common sense. Keep the cooling good by not resting it on a bed or anything that will insulate it. Buy a pad for it that keeps an air pocket underneath it if necessary. Run it in energy saving mode whenever possible.
Thanks for the advice everyone.
  • · Replies 17 ·
  • · Replies 20 ·
17K
  • · Replies 29 ·
  • · Replies 123 ·
21K
