Distance between atoms
by Legion81
Tags: atoms, distance
Legion81
Legion81 is offline
#1
Jul31-08, 10:28 PM
P: 70
Is there a way to find the distance between atoms? For example, if you have a pure gold film... how can you find out how far the gold atoms are spaced?
Phys.Org News Partner Physics news on Phys.org
Better thermal-imaging lens from waste sulfur
Scientists observe quantum superconductor-metal transition and superconducting glass
New technique detects microscopic diabetes-related eye damage
fluidistic
fluidistic is offline
#2
Jul31-08, 10:37 PM
PF Gold
fluidistic's Avatar
P: 3,173
I have an idea. Take a look at a periodic table of the elements and check out how much weight is worth a mole of the element you are trying to estimate its atoms distance. (Assume that your substance is free of all the other elements). Then as you know Avogadro's number, you know how many atoms there are in the "block" (or film as in your example) of the particular element (gold for you). Now it's getting a bit complex... hmm. I'm not sure it's as easy as I thought. Maybe by measuring the volume of your film it would be possible. Interesting question! I'll think on it more.
Legion81
Legion81 is offline
#3
Jul31-08, 10:51 PM
P: 70
That was the approach I first thought of, but surely there is some formula or something to just plug some numbers into... Google didn't bring up any results when I searched, so I was hoping someone knew.
Does anyone know of a table or something that has atomic distances for materials? (at X temperature, X pressure, etc.)
humanino
humanino is offline
#4
Jul31-08, 10:57 PM
humanino's Avatar
P: 2,828
One way is to shine it with X-rays and look at the diffraction pattern.
Legion81
Legion81 is offline
#5
Jul31-08, 11:33 PM
P: 70
Quote Quote by humanino View Post
WOW... Thanks! I bet that would work, but I was actually wondering about something on paper. I was playing around with some ideas, then I realized I had no idea how to find the distance between 2 atoms. So as you can see, an experimental value isn't really an option for me. I need a way that fits my budget... which is about a package of ramen noodles! LOL! I guess I'm out of luck.
peter0302
peter0302 is offline
#6
Aug1-08, 08:38 AM
P: 869
How about using good old fashioned chemistry (Avogadro's law, etc.)?
(Whoops, fluidistic beat me to it. :))
Check wikipedia. For at least some of the elements it gives you the Van der Waals radius which might be good enough for your purpuses.
NoTime
NoTime is offline
#7
Aug1-08, 08:50 AM
Sci Advisor
HW Helper
P: 1,572
scanning tunneling microscopy is another way to do this.
Gold 100 surface -> http://en.wikipedia.org/wiki/Image:A...tion_Au100.JPG
humanino
humanino is offline
#8
Aug1-08, 08:55 AM
humanino's Avatar
P: 2,828
I have to look it over, because I am not familiar with that. But I think by measuring the heat properties of your material, plus some condensed matter formalism, you should be able to determine the size of the lattice. I'm not completely positive because I don't remember all the hypothesis you need. Maybe Gokul could help us with that.
edit
Second thought, it is unlikely to work : you would probably need very high tempreatures.
Legion81
Legion81 is offline
#9
Aug1-08, 02:24 PM
P: 70
Quote Quote by peter0302 View Post
That should work just fine. Thanks for the help!
Register to reply
Related Discussions
Cells are made of molecules,molecules are made of atoms,atoms are made of energy.so.. Biology 9
Distance problem, Using Launcher need to find objects distance Introductory Physics Homework 2
could atoms ever run out Quantum Physics 12
Actual Distance Between Atoms of an Ideal Gas Atomic, Solid State, Comp. Physics 2
What do atoms look like? General Physics 48
