Register to reply
A rotating coil measuring the magnetic field
by lfused
Tags: coil, field, magnetic, measuring, rotating
Share this thread:
lfused
#1
Aug1-08, 11:35 AM
P: 7
A rotating coil is a common device for measuring magnetic fields. Consider a coil of area A and N turns that is rotated at angular frequency w in a magnetic field. The position of the coil is adjusted so as to produce a maximum induced current Imax which can be measured by using an appropriate ammeter. R is the total resistance of the coil circuit find the relationship between the unknown magnetic field and Imax
2. Relevant equations
E = -d(phi)/dt where phi = magnetic flux
E= IR
phi = BA where B is the magnetic field
E= -N *d(phi)/dt
3. The attempt at a solution
I'm not really sure what to do with this problem at all because we didn't really go over how angular frequency related to magnetic flux in class. Since w= (2*pi*r)/T meaning w is related to the change in time I tried using the equation IR= -(BAN)/w but I'm not sure if that's right.. and I wouldn't know how to determine the Imax from that. I know taking a derivative can help determine max and min by setting the equation equal to zero... but I really have no clue what I'm doing.
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
Irid
#2
Aug2-08, 09:50 AM
P: 208
The magnetic flux across the coil is
[tex]\Phi = NBA\cos \phi = NBA \cos \omega t\, .[/tex]
that is, varies sinusoidally. Taking the derivative, we find the induced EMF:
[tex]E = -\frac{d\Phi}{dt} = NBA\omega \sin \omega t\, .[/tex]
Ohm's law gives
[tex]I = \frac{E}{R} = \frac{NBA\omega}{R} \sin \omega t\, .[/tex]
The maximum value of current can now be clearly seen. So, you've almost guessed your equation right. Next time you could try using dimensional analysis to see if it's a legal expression or not.
Register to reply
Related Discussions
Radius of coil in magnetic field Introductory Physics Homework 5
A coil with turns given magnetic field, time find the emf induced in the coil Introductory Physics Homework 4
Magnetic Field at the Center of a Coil Introductory Physics Homework 3
Magnetic field through coil is given by mu*Current/2PI*r, right? Introductory Physics Homework 0
Magnetic field due to an elliptical coil Advanced Physics Homework 3
