Thread Closed
Critical Temperature in a Gas
Share Thread
Aug4-08, 08:12 AM   #1
Hi,
It is supposed a metal container hermetically closed and completely filled with water; the container is supposed to have unlimited strength, so doesn’t deform under internal or external pressure.
What will be happen if we heat the water over its critical temperature (374 C degrees – 705.2 F degrees)? Will it become steam? If yes, how? Because the container is fully filled with water and this is denser than steam (that is a gas).
If doesn’t become steam (gas), will continue the water increasing its temperature over the critical temperature as we increase the temperature we apply?
Thanks a lot.
PS – I apologize for my English, I am learning it.
PhysOrg.com physics news on PhysOrg.com
>> Cheap, color, holographic video: Better holographic video displays
>> First entanglement between light and optical atomic coherence
>> EUROnu project recommends building Neutrino Factory
Aug4-08, 10:30 AM   #2
Well, according to my understanding, above the critical temperature, that is supercritical water and there will be no phase separation. Therefore, there will be only one 'fluid' phase in the region above the critical temperature. it's neither liquid nor gas, but it's still water!Since your container is fixed at constant volume, the density is also fixed. So the water (in fluid phase) will continue increasing its temperature as you increase the temperature outside, until the water molecules decompose.
That is my opinion. If anyone find errors in my words, please correct it. Thanks.
Aug5-08, 06:58 AM   #3
Thanks Isloneil for your interesting answer.
Aug5-08, 07:01 AM   #4
Here is a Water Diagram about it: http://www.lsbu.ac.uk/water/phase.html
Thread Closed
Similar discussions for: Critical Temperature in a Gas
Thread Forum Replies
Critical Pressure and Temperature of a van der Waals Gas Introductory Physics Homework 3
formula or list needed for gas 'critical temperature' calc General Physics 0
Finding critical temperature from equation of state Biology, Chemistry & Other Homework 1
YBCO critical temperature not right Atomic, Solid State, Comp. Physics 3
Critical Temperature? Biology, Chemistry & Other Homework 2
