Rate of Change: Show dh/dt Proportional to h^(1/2)
The discussion revolves around a rate of change problem involving fluid dynamics in a cylindrical tank. Participants explore the relationship between the volume of fluid remaining in the tank and its depth, specifically how the rate of change of depth (dh/dt) is proportional to the square root of the volume (V).
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant presents a scenario where fluid flows out of a cylindrical tank, stating that the rate of flow is proportional to the square root of the volume remaining.
  • Another participant formulates the differential equation dV/dt = -aV^(1/2) based on the initial assumption and relates the volume to depth using the equation V(t) = πR²h(t), suggesting a rearrangement leads to the desired result.
  • A later reply emphasizes the importance of using static equations and the chain rule to connect rates of change in such problems.
Participants appear to agree on the formulation of the problem and the mathematical relationships involved, but the discussion does not reach a consensus on the broader implications or applications of the derived equation.
The discussion relies on assumptions about the proportionality constants and the geometric relationships between volume and depth, which may not be explicitly defined or universally applicable.
Readers interested in fluid dynamics, differential equations, or mathematical modeling of physical systems may find this discussion relevant.
padraig
Sorry to bore you all with this rate of change question, I really hate this area of maths and struggle to get my hea round it. Here it is, I'd be greatful for any help you have to offer:
Fluid flows out of a cylindrical tank with constant corss section. At the time t minutes (t is greater of equal to 0), the volume of fluid remaining in the tank is V m^3. The rate at which the fluid flows, in m^3min^-1, is proportional to the square root of V. Show that the depth h metre's of fluid in the tank satisfies the differential equation:
dh/dt = -kh^(1/2) where k is a +ve constant
Cheers
Pat
dV/dt=-aV^(1/2), by assumption.
V(t)=pi*R^(2)*h(t)=b*h(t) (where R is the radius)
Rearranging a bit, and introducing k yields the desired result
thanks v much, great help
Pat
In other words, the whole point of "rate of change problems" is to use a static equation (typically a geometry formula or something like that) that has no time variable, t, in it and then use the chain rule to differentiate both sides of the equation- giving a formula connecting the rates of change of the quantities.
