Hoffman.comHow does matter get converted into energy?
  • Context: Undergrad
  • Thread starter Thread starter electronman
    Equivalence
The discussion revolves around the mechanisms by which matter is converted into energy, exploring theoretical models, examples of energy forms resulting from such conversions, and the implications for mass-energy equivalence. The scope includes conceptual and technical aspects of physics, particularly in nuclear reactions and particle interactions.
  • Some participants inquire about models that describe how matter converts to energy and the nature of that energy.
  • It is noted that mass conversion typically results in electromagnetic radiation and kinetic energy of particles, with examples such as positron-electron collisions and nuclear fission.
  • Participants request references to support claims regarding mass-energy conversion to electromagnetic radiation.
  • One participant discusses the idea that energy changes forms while total energy and mass remain constant, using atomic nuclei as an example.
  • There is a discussion about whether pushing protons together results in a loss of mass due to increased potential energy, with differing views on the implications for energy conservation.
  • Some participants argue that adding energy to a system increases its mass, while others contend this does not violate conservation of energy if the system is not closed.
  • Clarifications are made regarding the distinction between energy and mass, emphasizing that they are equivalent but not the same.
Participants express differing views on the implications of energy addition to a system and its effects on mass and energy conservation. There is no consensus on whether pushing protons together results in a loss of mass or how energy conservation applies in this context.
Some statements rely on specific definitions of closed systems and energy forms, which may not be universally agreed upon. The discussion includes unresolved mathematical interpretations regarding energy and mass relationships.
electronman
Is there any model to describe the mechanism that allows matter to be converted into energy? If a mass is suddenly converted into its energy equivalent what is the nature of this energy?
When mass in converted into energy it typically comes out as electromagnetic radiation, although some of it might be in the kinetic energy of the particles (if any) that result from the reaction. Examples: positron-electron collsion leads to 2 511 kev gamma rays, nulclear fission leads to two nuclides plus neutrons plus gamma rays.
Thanks for the post. Any references to the statement that the mass energy is converted to electromagnetic radiation?
http://atom.kaeri.re.kr/ton/
The above is a table of all nuclides, including specifically the decay information about those that are radioactive. Any good book on nuclear physics would help also.
Google for "nuclear bomb..."
A search that would likely prove to contain much interesting information, perhaps not only to the people interested in particle physics. It's kind of off topic, but I have to wonder if such searches will gain unwelcome attention from beaurocrats overzealous to see everything as terrorist threats. Is it just me, or is anyone else concerned?
When it is said that mass is converted into energy it is meant that the energy changes from one form to another form. The total energy, like the total mass, remains constant. The form of the energy, and the form of the mass, changes. The form can go from potential energy to kinetic energy or radiant energy etc. Take the nucleus of an atom as an example. Classically you can think of the mass of the nucleus consisting of the rest mass of the individual particles plus the potential energy of the particles plus the kinetic energy of the particles. When the nucleus decays then what was potential energy changes to kinetic energy or radiant energy etc. The total mass remains constant though.
For a solid worked example please see
http://www.geocities.com/physics_world/sr/nuclear_energy.htm
Pete
When you push two protons towards each other there is an increase in potential energy. If energy and mass are equivalent is there a loss in mass of the system due to the increase in PE in order to preserve energy conservation?
No. You are adding energy to the system, which increases its mass.
If this is the case you violate conservation of energy.
I don't think so, because you are doing work (adding energy to the system) to push them together... The energy would be lost from whatever is pushing them together.
...right?
this is true
also, you're not necessarily adding mass to the system when you give it energy
just because energy and mass are equivalent doesn't mean they are the same
for example,
5-2 is equivalent to 3 but not the same as 3
It isn't, if the system was closed it would be.
Nope. Conservation of energy applies to a closed system. Obviously the system isn't closed if an outside agent can do work on it.
oops: jcsd beat me to it.
When you push two protons together then that work is at the expense of another part of the system or at the expense of another form of energy. E.g. if two protons are on a collision course and then stick together then the potential energy is increased at the expense of the original kinetic energy of the particles. The mass of the system remains constant though.
Pete
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 105 ·
12K
  • · Replies 21 ·
  • · Replies 28 ·
