Specific Latent Heat of Ice HELP
The discussion revolves around determining the specific latent heat of ice in joules per kilogram without using calorimeters. Participants are exploring the concept of latent heat and its measurement methods.
  • Some participants question the feasibility of determining latent heat without calorimeters and discuss the distinction between specific heat and latent heat. Others suggest alternative measurement methods involving vapor pressures and enthalpy calculations.
The discussion is active, with various interpretations of how to approach the problem. Some participants have offered insights into measurement techniques, while others express skepticism about the original poster's request.
There are indications of confusion regarding terminology, particularly the use of "specific latent heat." Participants are also considering the necessary equipment and conditions for accurate measurement.
xxpsychoxx
How do i determine this, in J/kg, without the use of any calorimeteres? Keep it simple please
Thanks :biggrin:
You can always just google it.
I don't think you can "determine" it without using a calorimeter.
Specific heat and latent heat are two different things. Are you supposed to find both of them?
Edit: just noticed that the unit, J/kg, is for latent heat. "Specific heat" and "heat capacity" are both equivalent shorter phreases for "specific heat capacity." I have never heard the use of the term "Specific Latent heat" but I'll not go out on a limb and say it's "wrong." It sure sounds funny though.
No matter how you find them, even without a calorimeter, you need mass-scale, a heater, a thermometer, and a stopwatch.
Measure vapor pressures of the solid and liquid phases; determine enthalpies of vaporization for both phases at 0 C; difference is enthalpy of fusion.
  • · Replies 17 ·
