| Thread Closed |
Equiv. stiffness matrix (Mech. circuit) for hydraulic flow circuit? |
Share Thread | Thread Tools |
| Aug8-08, 03:54 AM | #1 |
Dear All,
I need to represent a hydraulic system into an equivalent mechanical (spring-mass-damper) system. But actually, they have reverse analogy in terms of flow resistance and stiffness.. meaning, Force=stiffness(k)*displacement; but Flowrate=(Pressure drop)/Flow resistance i.e., for series and parallel combinations, k and flow resistances will have reverse analogy additions.. I formed a stiffness matrix using concept of FE global elemental matrices assembly.. (1 dof @ each element nodes) - by considering the flow resistances of hydraulic circuit as spring stiffness directly... Similarly, i used the same matrix assembly process to determine flow coefficients matrix for hyd. circuit - but ending up with FLowrate = Pressure drop * Flow resistance (wrong relation) ie. Ab=X instead of AX=b So, how can i represent my flow matrix now?? Only after achieving this, I can proceed forward.. Also let me know that whether I can replace all co-efficients of stiffness matrix with 1/R terms.. Or should I have to take inverse of that matrix and perform the calculations.. Help me out in reaching the soln.. Ur ideas/suggestions r most welcome… Thanks in advance!!! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Equiv. stiffness matrix (Mech. circuit) for hydraulic flow circuit?
| CIRCUIT ANALYSIS: Non-Inverting Ideal OpAmp, 2 resistors, 1 IVS - Find Thevenin Equiv | Introductory Physics Homework | 4 | ||
| Question regarding air flow in a closed circuit | General Physics | 10 | ||
| Confused about Equiv. Resistance for this Circuit | Engineering, Comp Sci, & Technology Homework | 5 | ||
| How do electrons flow in a circuit? | Introductory Physics Homework | 8 | ||
| electron flow in a circuit | Classical Physics | 18 | ||
