Curve Sketching Homework: Proving Range of Values of y
  • Thread starter Thread starter BadlyAddicted
    Curve
The discussion centers on proving the range of the function defined by the equation (x^2 - 2x + 2)/(x^2 + 3x + 9), specifically that the range of y is constrained between 2/27 and 2. The teacher transformed the equation into a quadratic form (y-1)x^2 + (3y+2)x + 9y - 2 = 0, emphasizing that the discriminant (b^2 - 4ac) must be non-negative for real x values. The coefficients are identified as a = y-1, b = 3y+2, and c = 9y-2, leading to the derived expression -27y^2 + 56y - 4 for the discriminant.
  • Understanding of quadratic equations and their properties
  • Familiarity with the quadratic formula
  • Knowledge of discriminants and their role in determining real solutions
  • Basic algebraic manipulation skills
  • Study the implications of the discriminant in quadratic equations
  • Explore the relationship between the coefficients of a quadratic and its graph
  • Learn about the concept of range in functions and its mathematical significance
  • Practice solving quadratic equations with varying coefficients
Students studying algebra, particularly those focusing on quadratic functions and their properties, as well as educators looking to clarify the concept of function ranges and discriminants.
BadlyAddicted
A curve has equation (x^2 - 2x + 2)/(x^2 + 3x + 9). I need to prove that the range of values of y for this curv eis 2/27 =< y =< 2
I know how it should be worked but I can't understand why it's done that way.
My teacher simply arranged the equation in the form (x^2 + 3x + 9)y = x^2 - 2x + 2 which leads to the equation (y-1)x^2 + (3y+2)x + 9y - 2 = 0 and then said "For range, b^2 - 4ac >= 0"
This is what I'm having trouble understanding. What does the range have to do with b^2 - 4ac >= 0. I want to know the reasoning behind this
I'd appreciate any answers :)
Thanks
You teacher used algebraic manipulation to write the equation as [itex](y-1)x^2 + (3y+2)x + 9y - 2 = 0[/itex], which you can think of as a quadratic equation for x, with the coefficients involving y.
The "range" of a function is the set of all possible y values. Here that means values of y that correspond to real number values of x.
Since that is written as a quadratic equation, use the quadratic formula to solve it.
Remember that the solutions to the quadratic equation [itex]ax^2+ bx+ c= 0[/itex] are given by [itex](-b\pm \sqrt{b^2- 4ac})/2a[/itex]. In particular, those will be real numbers as long as the value inside the squareroot, [itex]b^2- 4ac[/itex] is not negative. Here a= y-1, b= 3y+ 2, and c= 9y- 2.
[tex]b^2- 4ac= (3y+2)^2- 4(y-1)(9y-2)= 9y^2+ 12y+ 4- 4(9y^2- 11y+ 2)[/tex]
[tex]= 9y^2+ 12y+ 4- 36y^2+ 44y- 8= -27y^2+ 56y- 4[/tex]
thanks a lot for your help. i perfectly understand it now. thank you
  • · Replies 25 ·
  • · Replies 105 ·
13K
