Electromagnet Winding: 1200 Winds or 600 Winds?
  • Context: Undergrad
  • Thread starter Thread starter magnetic-man
The discussion centers on the comparison between using 1200 winds of AWG 30 magnet wire and 600 winds of AWG 15 magnet wire for high voltage electromagnets. It is established that AWG 15 wire, being 5.7 times larger in diameter and 32 times larger in cross-sectional area than AWG 30, has significantly lower resistance. Consequently, with the same voltage applied, the AWG 15 wire will draw 64 times more current, resulting in a magnetic field strength that is 32 times greater than that of the AWG 30 wire. For optimal electromagnet performance, a focus on high current rather than high voltage is recommended.
  • Understanding of electromagnetism principles
  • Familiarity with American Wire Gauge (AWG) standards
  • Knowledge of electrical resistance and current flow
  • Basic concepts of magnetic field generation
  • Research the properties of different AWG wires for electromagnet applications
  • Learn about calculating magnetic field strength based on wire specifications
  • Explore methods for increasing current capacity in electromagnet designs
  • Study the effects of wire length and gauge on resistance and performance
Electrical engineers, hobbyists building electromagnets, and anyone interested in optimizing electromagnet performance through wire selection and design considerations.
magnetic-man
Hey, anybody out there good with electrical stuff??
I'm no genius but can I be correct in assuming the following?
Im making high voltage electromagnets.
If I use 1200 winds of awg30 magnet wire, it will have the same power ~ (EMF) Or (magnetic field strenghth) as 600 winds of awg15 magnet wire. Am I correct in assuming this or No? The power source is the same, and voltage too for both cases.
No.
15 awg wire is 5.7 times larger in diameter than 30 awg, and 32 times larger in cross-sectional area. That means the 15 awg is 32 times less resistive than the same length of 30 awg. But since your 15 awg wire will be half the length of the 30 awg, it would be 1/64 as resistive.
So, for the same voltage applied to both wires, the 15 awg will draw 64 times as much current. With half as many windings, expect a 32 times larger magnetic field for the 15 awg.
A table of wire diameters for different awg's can be found about 1/2-way down this page:
http://en.wikipedia.org/wiki/American_wire_gauge
p.s. if you want to make a powerful electromagnet, try to make it high current rather than high voltage.
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 16 ·
