Thread Closed
Work required to move the charge
Share Thread Thread Tools
Aug8-08, 03:59 PM   #1
a 2.0 pico C charge is locted at point A on an imaginary spherical surface which is centre on a 4.0 micro C point charge 2.8 cm away . How much work is required to move the 2.0 pico C charge to the following two points?
a) to point B, which is located on the same spherical surface an arc length of 3.0 cm away
b) to point C, which is located radially outward from A on another imaginary spherical surface of radius 4.2 cm.
c)what name could be used to describe these spherical surfaces?
2. Relevant equations
I have no Idea but since the question is looking for work, im assuming this equation must be used
W= FDCosTheta
Electric force equation? FQ=K(q1q2/r^2)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Aug8-08, 06:55 PM   #2
Mentor
In your course, have they discussed electric potential or voltage yet? If so, that would be a "shortcut" to solving this problem.
If not then you'll have to use the equations for work and force to solve it.
Thread Closed
Thread Tools
Similar Threads for: Work required to move the charge
Thread Forum Replies
Work done to move a test charge Introductory Physics Homework 13
How to calculate work required to move an object Introductory Physics Homework 11
Work done to move a charge Introductory Physics Homework 12
The work required for adding a charge to an infinite charge distribution Advanced Physics Homework 1
how much work to move a charge? Introductory Physics Homework 2
