Spin, charge, and magnetic moment
The discussion revolves around the intrinsic properties of particles, specifically focusing on mass, spin, charge, and magnetic moment. Participants explore the relationships between these properties and question the classification of spin and charge as intrinsic while considering the role of magnetic moment.
  • Some participants note that mass, spin, and charge are considered intrinsic properties of particles, while questioning why magnetic moment is not classified in the same way.
  • There is a suggestion that both spin and charge can be derived from a particle's magnetic moment, leading to confusion about the classification of these properties.
  • One participant points out that determining charge from magnetic moment is problematic, particularly for particles like neutrons and photons.
  • Another participant mentions the equation relating magnetic moment, charge, spin, and mass, indicating that these quantities can be interdependent.
  • Some participants propose that magnetic moment could be considered a fourth intrinsic property, while others argue that it is dependent on the particle's spin.
  • There is a discussion about the neutron's magnetic moment despite its neutrality, with references to the quark composition contributing to this property.
  • A later reply emphasizes that the g-factor varies among particles and that the equation for magnetic moment is not universally applicable to all particles.
Participants express differing views on whether magnetic moment should be classified as an intrinsic property alongside mass, spin, and charge. The discussion remains unresolved regarding the classification and interdependencies of these properties.
Participants acknowledge the complexity of determining intrinsic properties experimentally and the potential for errors in measurement, particularly regarding spin values.
This discussion may be of interest to students and professionals in physics, particularly those exploring particle properties and their interrelationships.
Monocles
I've read that the properties considered intrinsic to a particle are its mass, spin, and charge. However, unless I am mistaken, both spin and charge can be determined from a particle's magnetic moment. Why are spin and charge considered to be intrinsic instead of magnetic moment then? Sorry if this is a silly question, I'm a physics major but the only physics class I've taken is physics 1.
EDIT: I just realized that you'd be trying to determine two quantities with just one equation. In which case, why isn't it that you can't call any two of those properties to be intrinsic and the third to be the one "left over"? Is it arbitrary?
How do you propose to determine the "charge" of a neutron from its "magnetic moment"? What about the "magnetic moment" of a photon? Where do you get that to determine that it has a spin of 1?
Zz.
Whoops, I just looked up the equation again, and I missed the first time that it related magnetic moment, charge, spin, AND mass.
[tex]\mu = g\frac{q}{2m}S[/tex]
I am under the impression that magnetic moment, charge, and mass are determined experimentally, while spin is found from an eigenvalue problem or something like that. So, you can determine any of the quantities from the other 3, which still leaves the question of why spin, mass, and charge are intrinsic and magnetic moment is not. Because of experimental error getting a integer or half-integer value for spin would have to be fudged, I think.
So, I am saying to determine a particle's magnetic moment experimentally, and use that, along with its mass and spin to determine its charge (for example).
It still doesn't explain how you would use that to apply to neutrons and photons (for example).
Zz.
Magnetic moment is a fourth intrinsic property of a particle.
The four are mostly independent. A particle must have spin to have a magnetic moment,
and there are theoretical relations between spin and magnetic moment for
some particles, where the g in your equation can be determined.
Oh ok, so they are all intrinsic properties? I see now that the g-factor is different from particle to particle. I didn't know that the equation wasn't valid (yet?) for all particles. That makes me wonder though, why does the neutron have magnetic moment if it is electrically neutral? Is it because of the quarks inside of it not being electrically neutral?
Also, that answers my question, clem, if magnetic moment is a fourth intrinsic property of a particle. Thanks!
You can use your formula for g only for fundamental particles. Indeed the neutron is not a point particle. The details of how to construct its magnetic moment from the quarks is still under investigations.
  • · Replies 27 ·
