Recursive solution of determinants
  • Context: Graduate
  • Thread starter Thread starter Chen
    Determinants
The discussion revolves around the recursive solution of determinants for a specific matrix defined by M_{ij} = A δ_{i,j} - B δ_{i,j-1} - C δ_{i,j+1}. Participants explore the derivation of the determinant D_N and the form of its solution, including initial conditions and the method of solving recurrence relations.
  • One participant describes the matrix and the recursive relation for its determinant, D_N = A D_{N-1} - B C D_{N-2.
  • Another participant notes the assumption of a solution of the form D_N = λ^N and identifies the roots λ_{±} = (A ± √(A² - 4BC)) / 2.
  • Initial conditions D_1 = A and D_2 = A² - BC are mentioned as critical for finding the general solution.
  • A participant questions the final form of the solution D_N and expresses confusion about its derivation.
  • Another participant suggests that the solution can be expressed in a form consistent with the general method for solving recurrence relations, providing a specific expression for D_N.
  • A later reply acknowledges the oversight in understanding the solution's form.
Participants generally agree on the method of solving the recurrence relation, but there is some confusion regarding the specific form of the solution and its derivation.
There may be limitations related to the assumptions made in deriving the recurrence relation and the specific forms of the solutions, which are not fully resolved in the discussion.
Chen
Hi,
I'm reading a paper where the determinant of the following matrix is solved for using some kind of recurisve method.
The matrix is given by [tex]M_{ij} = A \delta_{i,j} - B \delta_{i,j-1} - C \delta_{i,j+1}[/tex], with [tex]i,j = 1...N[/tex] and are NOT cyclic.
The author sets [tex]D_N = \texttt{det}\[M_{(N)}\][/tex] and writes the equation
[tex]D_N = A D_{N-1} - B C D_{N-2}[/tex],
assumes a solution of the form [tex]D_N = \lambda ^N[/tex] and finds two solutions,
[tex]\lambda_{\pm} = (A \pm \sqrt{A^2 - 4 B C}) / 2[/tex].
He then notes the initial conditions of [tex]D_1 = A[/tex] and [tex]D_2 = A^2 - B C[/tex] and says that the answer is therefore
[tex]D_N = \frac{\lambda_{+}^{N+1} - \lambda_{-}^{N+1}}{\lambda_{+} - \lambda_{-}}[/tex].
It's the very last step I don't understand, how did he find [tex]D_N[/tex]?
Thanks
After a bit of search I see that the method to solve this kind of recurrence relations is to assume a solution of the form [tex]A \lambda_1^N + B \lambda_2^N[/tex] and find A and B from the initial conditions. However this is not exactly the form of the solution here... how come?
Why isn't it?
[tex]D_N= \frac{\lambda_+}{\lambda_+-\lambda_-}\lambda_+^n+ \frac{-1}{\lambda_-(\lambda_+-\lambda_-)}\lambda_-^n[/tex]
is exactly of the form you give.
Yes that would be correct, a bad case of dullness. Thanks.
  • · Replies 25 ·
