What is the physical origin of gain in a BJT?
The discussion centers on the physical origin of gain in a Bipolar Junction Transistor (BJT), exploring the underlying semiconductor physics and operational principles. Participants seek to clarify how a small input signal can produce a larger output signal, while addressing the conservation of current in the process.
  • Homework-related
  • One participant compares the BJT to a valve, suggesting that it leverages its characteristics to amplify signals.
  • Another participant emphasizes the importance of conservation of current, questioning how semiconductor physics contribute to the gain.
  • A participant explains that the heavy doping of the emitter compared to the collector and base leads to a majority of charge carriers being generated at the emitter, which contributes to the gain.
  • It is noted that the narrow path of the base allows most charge carriers to spill over into the collector, resulting in a small base current relative to collector and emitter currents, thus yielding high gain.
  • One participant cautions that explaining the gain in detail requires complex equations and an understanding of p-n junction behavior, mentioning that the mode of operation (forward-active or reverse-active) affects the gain.
  • Resources such as textbooks and Wikipedia are suggested for further reading on the topic.
Participants express varying levels of understanding and approaches to explaining the gain in a BJT. There is no consensus on a singular explanation, and the discussion reflects multiple perspectives on the topic.
Participants acknowledge that a comprehensive explanation of the gain in a BJT involves complex equations and a fundamental understanding of semiconductor physics, which may not be fully addressed in this discussion.
atlbraves49
"What is the physical origin of gain in a BJT?"
I can figure out gain using gain equations but am having a hard time describing the physical origin of gain in a BJT.. can anyone help?
Think of a valve. How do you leverage the characteristics of the BJT to input a small signal and get a much larger signal at the output?
Bear in mind that despite the notion of a "gain" relative to desginated inputs and outputs, conservation of current still holds here. Are you asking how exactly do the semiconductor physics of the BJT cause a "gain" in output?
correct, that is what I'm asking.
I'll try to be rather brief in my explanation (it took me a while to understand BJT's and I'm still working on it.)
The key is that the emitter is doped very heavily compared to the collector and base. So most of the conductors are "created" at the emitter node. (electrons for npn types, or holes for pnp)
Also, the base node lies at the end of a very narrow thin path sandwiched between the emitter and collector. So most of the conductors from the emitter just "spill over" into the collector instead, as they try to make their way towards the base. Only a few conductors do make it to the base.
The result is that the base current is much smaller than the collector and emitter currents, hence the high gain given by the ratio
ic / ib
First of all, if that is what you're asking you should note that this isn't something which can be explained in a few short paragraphs. It would require equations, a lot of variables with subscripts along with accompanying concentration profile graphs and a fundamental (read: basic) understanding of p-n junctions and how they behave under forward and reverse bias.
In short, it's not something that can be done here. Moreover you didn't specify the mode of operation. There are 4 possible modes, and only two modes "forward-active" and "reverse-active" would yield a current gain. The forward-active mode is the much more commonly used one. Read up on the mechanism elsewhere. Personally I used Semiconductor Physics 3rd Edn by Donald Neamen.
Wikipedia has good info on this:
http://en.wikipedia.org/wiki/BJT#Introduction
  • · Replies 17 ·
12K
  • · Replies 23 ·
