Register to reply
What types of metals are typically in wires?
by stickythighs
Tags: metals, types, typically, wires
Share this thread:
stickythighs
#1
Aug10-08, 01:44 PM
P: 72
What type of metal are typically in wires?
I believe that usually wires are made out of copper. Are most wires made out of copper?
Does the size of the wire usually determine what metal is in a wire? For instance, are larger wires typically composed of copper, while smaller wires are typically composed of iron?
Is iron ever used in wires?
Is steel ever used in wires?
Is aluminum used in wires?
I would like a general overview of the types of metal in wires.
Phys.Org News Partner Science news on Phys.org
Suddenly, the sun is eerily quiet: Where did the sunspots go?
'Moral victories' might spare you from losing again
Mammoth and mastodon behavior was less roam, more stay at home
mgb_phys
#2
Aug10-08, 02:26 PM
Sci Advisor
HW Helper
P: 8,955
Generally electrical wires are copper because it has very good electrical conductivity. The wiring in some american houses form the 70s are aluminium because of the high price of copper at the time. The electrical wires on high voltage pylons are generally aluminium, although it is a poorer conductor than copper it is much lighter so can be thinner to support it's own weight.
Wires used on suspension bridge cables are steel.
Redbelly98
#3
Aug10-08, 02:48 PM
Mentor
Redbelly98's Avatar
P: 12,064
Also, wires used as filaments in light bulbs are made from tungsten.
stickythighs
#4
Aug10-08, 03:03 PM
P: 72
mgb phys,
I appreciate the pithy remarks of your response.
What are high voltage pylons?
hage567
#5
Aug10-08, 03:32 PM
HW Helper
P: 1,542
Quote Quote by stickythighs View Post
They are these things:
http://en.wikipedia.org/wiki/Electricity_pylon
Sakha
#6
Aug10-08, 05:31 PM
P: 295
On some very precise applications they sometimes use Silver alloys wires and for applications that require really small wires and very little corrosion gold is sometimes used.
Astronuc
#7
Aug10-08, 07:07 PM
Admin
Astronuc's Avatar
P: 21,806
Quote Quote by mgb_phys View Post
In some cases, some transmission lines are comprised of Al strands around a steel core.
Piano wires are steels - specifically 'spring steel'.
Guitar strings are steel or bronze wound around steel cores.
mgb_phys
#8
Aug10-08, 09:12 PM
Sci Advisor
HW Helper
P: 8,955
I forgot to add, the wires inside a computer chip, connecting between the silicon and the pins are often gold. Gold can be stretched into much finner wires than any metal.
NoTime
#9
Aug11-08, 01:19 PM
Sci Advisor
HW Helper
P: 1,571
Any metal that can be formed into a wire, is made into wire for one application or another.
If by wire you mean conductive connector then you can include some non metals like polymers or carbon nanotubes.
Redbelly98
#10
Aug12-08, 07:46 AM
Mentor
Redbelly98's Avatar
P: 12,064
While I'm hesitant to drag this thread out further, owing to the OP's lack of response, I am compelled to add:
Nickel-chromium ("Nichrome") resistance wire is used to make heater elements.
Register to reply
Related Discussions
Types of bondings Biology, Chemistry & Other Homework 2
Types of DE Differential Equations 1
N-Type semiconductor Silicon Electrical Engineering 4
Online resource for type theory? Set Theory, Logic, Probability, Statistics 33
Typically Dem voting populace: seismic shift Current Events 9
