How Can I Ensure High Quality When Burning Audio CDs for My Truck?
  • Thread starter Thread starter dingpud
    Audio Quality
The discussion revolves around the factors influencing the quality of audio CDs burned for playback in a truck's CD player. Participants explore various aspects such as file formats, CD quality, and the impact of environmental noise on perceived audio quality.
  • One participant inquires about controlling factors for high-quality audio CD burning, mentioning bit rate and the quality of CDs.
  • Another participant states that burning regular audio files results in indistinguishable copies from originals, while compression to MP3s may sacrifice quality.
  • Concerns are raised about the reliability of low-cost writable CDs, with a suggestion to avoid very cheap options due to potential failure rates.
  • A participant emphasizes that CD data specifications (44.1 kHz, 2 channel, 1.4 megabits) are fixed and not adjustable, highlighting the importance of source quality.
  • There is mention of the APE format, which compresses audio less but may not be practical for use in a truck without a laptop.
  • One participant expresses uncertainty about settings that could improve the burning process after experiencing issues with a CD.
Participants express differing views on the importance of CD quality and the impact of compression on audio fidelity. There is no consensus on the best practices for ensuring high-quality burns, as opinions vary on the significance of various factors.
Participants note limitations regarding the quality of source files and the potential variability in the performance of writable CDs based on price and brand. There are also unresolved questions about optimal settings for burning CDs.
dingpud
What are the things to try and control when attempting to burn a high quality audio CD for my CD player in my truck?
I am sure there is a bit rating on the file, but are there other things that I can change to get better quality out of my burns?
Do better quality CD's make a difference? If so, any recommendations?
Thanks,
Computer science news on Phys.org
If you burn them as regular audio files (duplicates) the disks will be indistinguishable from the originals. If you compress them to MP3s, that's when you will have to start weighing the sacrifice of quality vs the extra capacity. When you're flying down the road with noise from the drive-train, wind, tire noise, etc, is the little loss of quality from fairly heavy compression going to be noticeable to you? Only your ears can tell you that.
BTW, the "quality" of the writable CDs is a very minimal player here. Get them on sale, protect them from road-dust and abrasion, and keep them in a safe place. They'll last.
Just be careful about "on sale" for too low a cost. Sometimes, you get what you pay for. Do you want a pack of CD's that cost about 50 to 75 % off, including some rebates? Maybe one-third of the discs will work, and the rest are bad. Buy good discs; do not buy cheap discs.
BTW, cd data is cd data: 44.1 khz, 2 channel, 1.4 megabits, uncompressed. It isn't adjustable.
As said, the determining factor is the quality of the source, assuming you are doing a mix of other digital files.
I have backed up tons of data (images, research, etc) to CDs that I ordered from Staples during sales and promotions. I don't recall ever tossing a disk because it wouldn't format or write properly. If you are having problems of that magnitude, you should either clean your CD writer or buy a new one. Something is not right.
There is also the APE format, which compresses a lot less, but retains all the information, but that won't work in a truck. Unless you take your laptop.
http://www.monkeysaudio.com/
I must have had a bad CD.
Wanted to make sure that I wasn't missing any settings that would improve things.
Thanks to all...
