Troubleshooting a Dead Laptop: Common Issues & Solutions
  • Thread starter Thread starter Andre
    Laptop
The discussion revolves around troubleshooting a dead laptop, specifically a Compaq Presario A900, after it unexpectedly shut down. Participants explore potential causes, diagnostic steps, and recovery options, including the implications of reinstalling the operating system without prior troubleshooting.
  • One participant describes the laptop shutting down unexpectedly and encountering errors when attempting to start Windows, leading to a decision to reinstall the operating system.
  • Another participant expresses confusion about the issue and suggests that the problem might stem from a critical Windows file, questioning the stability of the AC power supply.
  • A different participant mentions the absence of a Windows CD and the reliance on a recovery partition, noting that the power supply was stable and the battery was charged.
  • One participant suggests that using a Linux live CD could have been a better approach for diagnosing and repairing the issue before opting for a reinstall.
Participants do not reach a consensus on the best approach to troubleshoot the laptop. There are multiple competing views regarding the causes of the shutdown and the appropriate steps to take in such situations.
Limitations include the lack of a Windows CD for recovery, reliance on a recovery partition, and the absence of diagnostic tools due to the laptop's inoperability. The discussion does not resolve the underlying technical issues or the effectiveness of the proposed solutions.
Andre
:frown:
So I returned to my laptop (Compaq Pressario A900) after a coffee break this morning and found it to be off. I was quite sure I did not shut it down, Anyway, I attempted to restart it. After some initial startup noises it shut down again. :bugeye:
So hit start again toggling F8 safe mode, which informed me that it could not start windows. But there were several options, register restore - no luck, memory check - no errors, disk check no errors, So went thruogh all of them, getting error messages (address error for a file) at the moment windows should run.
In the end there was only one option left: reinstall windows (do you want to save data first? yes? install external memory unit! Inserted memory stick, enter. Nothing detected install external memory, other port, same effect, no data storage and lost the data etc.
So it was reinstalling day, and worse yesterday I cleared all the SD cards with dozens of pictures, now lost :frown:
Fortunately my main system, still somewhere in a moving box, contains the main data, but anyway.
So what happened? and is this common and what should I have done differently?
Computer science news on Phys.org
I wish you would have posted it up here before reinstalling in case we might have been able to help.
By what your describing I'm having a little trouble understanding what the problem could have been. One of those things where i'd have to play with the system to see how far you can get before encountering a problem. How stable is the AC power in your house? Does it ever surge at all?
From the sound of it, something screwy happened with a critical Windows file(s), but it's a little odd that the system was powered off when you found it. Usually it will restart and idle while showing you options or just plain halt and idle when the error happens. On rare occasions you'll get the infinite restart loop. Fist thing I would have done is put in the Windows CD and run the disk check utility, then perform a Windows repair by again booting from the Windows CD and running the Recovery Module.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;314058
http://pcworld.about.com/magazine/2109p156id111652.htm
Thanks B.Elliot.
There is no windows CD. I had made a recovery DVD but it's dislocated due to movings. Trying to get online and discuss things, unfortunately, was most impractical without the laptop.
So I had to cope with the recovery partition on the hard disk which seemed to be working fine.
The AC power was not a factor, the power LED's were on and the battery was fully charged all the time. Yet, it had shut down and it shut down again on normal attempts before activating Vista.
So I thought I had to make a trade off between losing files or keeping offline, fighting, while obviously, the system had exhausted all its options.
Oh Andre, so sad!
It was not a happy day Evo
You shouldn't have reinstalled right away, you could have used a Linux live CD to try to diagnose and repair the problem. The same thing happened to my dad with his laptop, and he made the same mistake.
  • · Replies 123 ·
21K
9K
  • · Replies 19 ·
15K
16K
11K
