Which snake is the longest in the world - George's or Shon's?
  • Thread starter Thread starter some_one
The discussion revolves around a logical reasoning problem comparing two snakes, one belonging to George and the other to Shon, focusing on their lengths and classifications as water or black snakes. Participants explore the implications of various statements based on the properties of these snakes.
  • Homework-related
  • Some participants assert that George's snake is the longest water snake, while Shon's snake is the longest black snake.
  • One participant questions which properties must hold true to conclude statements about the snakes based on the initial data.
  • Another participant cancels the first two statements, suggesting that the properties could coexist without being the longest snake.
  • There is a debate about the implications of statements 3 and 4, particularly regarding how the properties of one snake affect the other.
  • One participant argues that if Shon's snake is a water snake, it must be shorter than George's, leading to a contradiction if George's snake is also black.
  • Another participant concludes that statement 3 is correct, reasoning that if Shon's snake is a water snake, it cannot be the longest black snake and still allow George's snake to be black.
Participants express differing views on the validity of the statements regarding the snakes, with some agreeing on the correctness of statement 3 while others remain uncertain about the implications of the properties of the snakes.
The discussion includes assumptions about the properties of the snakes and their relationships, which are not fully resolved. The implications of the statements are debated without consensus on which statements are definitively true.
some_one
data:
the snake of goerge is the longest water snake in the world.
the snake of shon in the longest black snake in the world.
which one of the answers can be concluded from the data?
1.the snake of goerge is not black,and the snake of shon is not a water snake
2.if the snake of george is not black then the snake of shon is a water snake
3.if the snake of shon is a water snake then the snake of george is not black
4.if the snake of shon is a water snake then the snake of george is black
Biology news on Phys.org
To the others in Brain teasers forum:
I suggested to some one that he might get help from you guys here, so treat this less as a challenge to be answered forthwith than a homework problem OP can work through.
Take a crack at 1, some one:
This says that TWO distinct property holds.
Which two are those?
And, BOTH of those must be true if you were to be able to conclude it from the data. MUST both true, or must only one be true, or neither of the statements must be true?
i canceled the first and the second statement
because they could have also the other property
although not being the longest snake for tis property
but regarding the third and the 4th answers
i can't understand how can they link that if one snake has some property
then it affects the properties of the other?
Well, take 3 (and 4).
If shon's snake is a water snake, then that means shon's black water snake is the longest black water snake in the world.
(after all, it is the longest of all black snakes, hence longer than any other black water snakes..)
Can therefore george's water snake be black and still remain the longest water snake?
3 says no to that, 4 says yes.
Which is the correct answer?
the answer is 3
i can't understand why its 3
if shons snake is also a water snake
so he is the longest black snake but
not the longest water snake
so goerges snake can be the longest water snake but not the longest black snake
those two options do not collide with one another
why geoges snake cannot be black??
Sure it does!
Remember that george has the longest water snake.
If shon's snake is a water snake, it has to be shorter than george's snake (agreed?) (*)
But, we know that shon's snake is the longest of black snakes.
Therefore, IF george's snake is black, then it must be shorter than shon's (**)
(*) and (**) contradict each other.
Therefore, (**) cannot be true, since (*) is true by assumption.
Therefore, george's snake cannot be black if shon's snake is a water snake.
the answer is 3
if shon's snake is a water snake then it is the longest black snake but must be SHORTER than george's snake,now, if george's snake is a black snake than it's the longest water snake but it must be SHORTER than shon's snake, but it can't be because shon's snake is already shorter than george's snake -> hence george snake ain't black
i got it
thanks
12K
  • · Replies 59 ·
