Can Plasma Convert Water into Vapor for Mechanical Use?
  • Context: Undergrad
  • Thread starter Thread starter shintashi
    Plasma Reaction Water
The discussion centers on the potential of using plasma to convert water into vapor for mechanical applications, particularly in the context of plasma cutters. Participants explore the feasibility of employing a plasma "spark plug" in a pressurized water cylinder to generate significant vapor pressure. It is established that high-pressure water can act as a lubricant and that plasma's heat could facilitate the vaporization of water, akin to the operation of modern steam engines. The conversation also touches on the erosion effects of high-velocity water on materials, emphasizing the need for durable components like sapphire nozzles in water jet systems.
  • Understanding of plasma physics and its applications
  • Knowledge of high-pressure water systems and their mechanics
  • Familiarity with steam engine operations and thermodynamics
  • Awareness of material properties under high-pressure conditions
  • Research the principles of plasma generation and its interaction with water
  • Explore the design and functionality of high-pressure water jet systems
  • Investigate the Rankine cycle and its applications in modern power plants
  • Study the erosion characteristics of various materials under high-velocity water conditions
Engineers, researchers in thermal dynamics, and professionals in mechanical engineering who are interested in innovative applications of plasma technology and high-pressure systems.
shintashi
what happens to a body of water when coming in contact with plasma - such as the plasma cutters? I've been thinking if you had a cylinder filled with some water and something like a plasma "spark plug" you could get some serious vapor pressure.
Is this an accurate estimation, or am I way off? If it is accurate, then is it possible to use water as a combustion material - like a modern steam engine?
I seem to recall at extremely high pressures, water acts like a lubricant.
The water would be heated, and perhaps boil or vaporize with sufficient heat transfer. The water would have to be pressurized, which is what high pressure water jets do for cutter. They require sapphire nozzles because metals would corrode and erode.
http://www.kmtgroup.com/opencms/en_US/waterjet_systems/home/?gclid=CPDA-_HBiJUCFQ-SHgodxSnxrQ
http://en.wikipedia.org/wiki/Water_jet_cutter
http://www.iwmwaterjet.com/
In a steam engine, most of the water is boiled by heat from a fire. Water vapor is a combustion product, but is very small compared to the mass of water that is boiled. Steam locomotive exhausted steam in an open cycle, whereas many electrical plants using the Rankine (steam) cycle have a closed loop.
At high pressure, or rather high velocities, water erodes materials.
I have heard about http://www.cnjete.net" cutting only, and with laser maybe possible, but never heard with plasma
  • · Replies 28 ·
  • · Replies 29 ·
