Thread Closed
Why aren't heavier metals like uranium and mercury found in abundance in the core?
Share Thread Thread Tools
Aug12-08, 10:14 PM   #1
I'm curious as to why there aren't heavier metals in the earth's core than iron and nickel. Why those two? Anyone have any insight?
PhysOrg.com
PhysOrg
earth sciences news on PhysOrg.com
>> Oklahoma twister tracked path of 1999 tornado
>> Alaska volcano's ash prompts flight cancellations
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
Aug13-08, 04:38 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by danielandpenn View Post
Hi danielandpenn ! Welcome to PF!
There are … see http://en.wikipedia.org/wiki/Core_(earth_science):
The core of the Earth is still hot because it contains radioactive uranium and thorium atoms. Although the core is mostly iron, it also contains most of the Earth's uranium.
Aug13-08, 05:49 AM   #3
Nickel and iron are more abundant in the universe (or at any rate in the Solar system) than heavier substances, and might therefore dominate the core even if most of these other substances would have accumulated there.
On the other hand, some substances, like iodine, or mercury, might be mostly locked into molecules with less density than iron, or dissolved into subtances with less density than iron, like aluminium or water, and might therefore not be more abundant in the core than in the mantle or crust.
Aug13-08, 05:51 AM   #4
Recognitions:
Welcome, Danie
What happens in the core is all pure hypothetical, since we have only some very indirect observations. The wiki ref of tiny-tim is certainly true qualitatively but there is no way of quantifying the concentration of heavy elements in the core as well as their contribution to the terrestrial generated heat. There are more hypotheses going around, none of which can be selected as being the right one.
The iron - nickle abundance is no doubt related to the total abundance of those elements in the solar system, whereas the heavy elements are much more rare.
Another element could be, the order in which compounds became fluid or not, during the -hypothetical- iron catastrophe
But in the end it's all a sophisticated guess.
Aug18-08, 04:38 PM   #5
Recognitions:
Quote by Andre View Post
Welcome, Danie
Gee, I thought it was one big diamond at the centre... or is that Jupiter
Actually, I'd like to ask a question related to this one.... and that is why is gold associated with volcanic activity? Does it get separated out by extreme heat or is it of greater abundance in the liquid magma surfacing during a volcanic eruption?
Many thanks!
Aug18-08, 04:58 PM   #6
Recognitions:
Quote by baywax View Post
Gold isn't very chemically active but is soluable at very high pressures. It is carried along cracks by steam/fluids from volcanoes and is deposited out as they cool. So are lots of other metals, there a bunch of elements like platinum and telurium that you find along with gold.
Aug18-08, 05:39 PM   #7
Recognitions:
Quote by mgb_phys View Post
Ah, right! The chinese who built most of the CN and CPR railways across Canada would keep what they called "white gold" (platinum) in their old opium jars. It was considered useless at the time by the CDN and USA placer miners, but the "Coolies" kept it just the same.
Aug21-08, 05:47 AM   #8
If the core of Jupiter is made of diamond, that would mean that carbon is dominating Jupiter's core. One would have to conclude that elements heavier than carbon (such as iron and nickel) are relatively rare on Jupiter. In that case iron and nickel cannot be all that common in the Solar System, and one would have to wonder why they are common on Earth.
That is quite different from the case for hydrogen. Hydrogen is the most common element in the universe, but Earth cannot keep hold of it (except in compounds with heavier elements, such as oxygen), because it is light enough to escape from Earth's gravity well. Jupiter is more massive, and was therefore able to retain more hydrogen.
Carbon, however, would not escape from Earth, at least not over the present age of the Solar System. If a large part of Jupiter is made of carbon, that would be strange.
Aug21-08, 11:15 AM   #9
Recognitions:
Quote by Almanzo View Post
Very interesting. Do we know what the predominant metal/other is at Mar's core? Does the volcanic activity of Io, next to Jupiter, indicate a core content similar to earth's?
Aug21-08, 11:24 AM   #10
Recognitions:
We don't have direct seismic data for mars but it is thought to be similair to Earth. The difference is that Mars is smaller and so it's core cooled and solidifed and so has no (significant) magnetic field.
The volcanic activity of Io is due to the energy input from Jupiter, from tidal forces, it is too small to have a liquid core purely from internal heat sources. It does look like it has an iron core from magnetic field measurements made by the Galileo probe.
Aug21-08, 02:12 PM   #11
Recognitions:
Retired Staff Staff Emeritus
To my knowledge, there is no real evidence of any significant amounts of carbon in Jupiter's core. The diamond core theory was made up by Arthur C. Clarke for one of his later Odyssey novels.
There is definitely more realistic speculation of metallic hydrogen in jupiter's core, but I don't think that's been verified either.
Aug21-08, 10:28 PM   #12
Quote by Gokul43201 View Post
Wouldn't it be too hot for diamonds in the core of a planet? Wouldn't they burn up, or would the pressure prevent that?
Aug21-08, 10:40 PM   #13
Recognitions:
I'm sorry, I mentioned the diamond centre of Jupiter as a joke... sort of sarcastic kind of thing.
Aug21-08, 10:47 PM   #14
Recognitions:
Quote by sketchtrack View Post
You need oxygen for things to burn, also Carbon has a rather high boiling point (4000K)
Diamond isn't the most stable form of Carbon, diamonds (slowly) decay into graphite at room temperature - I don't know about at the pressure in the centre of a planet
Aug21-08, 11:33 PM   #15
Recognitions:
You need oxygen for things to burn and Carbon has a rather high boiling point (4000K)
So, how long till the engagement diamond turns into a pencil? Probably longer than the license takes to decompose, eh?.
Aug22-08, 04:57 AM   #16
Recognitions:
Boiling point of carbon is even a bit higher, 5100K and the melting point (grafite) is 3773K. The temperature of the Earth core is estimated at about 4-5000 oC. But the tremendous pressure would probably prevent carbon to be fluid.
Aug22-08, 07:34 PM   #17
Could one assume that if there is carbon in or near the core, it is probably in diamond form?
Thread Closed
Thread Tools
Similar Threads for: Why aren't heavier metals like uranium and mercury found in abundance in the core?
Thread Forum Replies
abundance of isotopes Chemistry 2
CPU differences: quad core, dual core, etc. for CFD Mechanical Engineering 3
Percent Abundance Introductory Physics Homework 1
the problem with abundance.... (link) Computing & Technology 5
Relative Abundance? Introductory Physics Homework 2
