Thread Closed
How we know the pressure drop ? plz help
Share Thread Thread Tools
Aug13-08, 01:55 PM   #1
I really need your help..
will explain to u what I am going to do exactly
1) I have to built a filter pilot plant for water treatment
For this filter, i have decided that to built the filter with three sections two PVC columns sections and one in the middle is Perspex column ( clear acrylic ) 300mm in outside diameter and 1m length.. but we prefere the thickness would be around 8mm
2) i can tell u that: i need to pump water from the bottom section of the filter which will be a PVC section,, and the flow rate will be around 180 L/H.to 300 L/H.. and the velocity will be around 5m/h and 10m/h..and i will put some materilas ( polymer beads ) inside the filter that will treat the water. i will pump air as well from the bottom to wash the materials once it is dirty..
By the way: my flow will be upflow
My qusestions are
1- What is the downflow wash water for floating media filter ? and what is upward wash air for floating media filter ? Is there any range ? in oder words : what is the typical backwash rate for upflow floating media filter ?
2- Could i calculate the amount of water and air the i need it for backwashing the media ? Could u help me with it ?
3- How can i calculate the pressure loss through the media before running any experiments ?
4-What about the required pressure of the system ?
I really have no feeling about these questions.. so could u help me with them ?
Best regards
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: How we know the pressure drop ? plz help
Thread Forum Replies
PRV valve pressure drop Mechanical Engineering 5
Bernoulli's Pressure Drop Segregated from Friction Pressure Drop General Physics 7
pressure drop Introductory Physics Homework 7
Pressure drop General Physics 2
Drop in Pressure Over A Given Distance Introductory Physics Homework 4
