Thread Closed
Re: Higgs Particles & Scale-Invariant Metrics & Breaking Scale Symmetry
Share Thread Thread Tools
May11-04, 05:09 AM   #1
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>"Hatim Hegab" &lt;htm_00@hotmail.com&gt; wrote:\n&gt; Can someone here give me a good idea about Higgs theory?, or provide me with\n&gt; some sites that can help?\n\nIt\'s a way of explaining away mass dynamically. So the "m"\'s\nin the Lagrangian are then not constants but actually fields --\nin fact, the same field multiplied by different coupling constants\nfor each type of particle. The field is permanently turned on by\na negative potential energy (negative, that is, relative to the\npotential when the field is turned off). So, if H is the magnitude\nof the field, the potential would be something like:\nk (H^2 - v^2)^2.\n\nRelative to the condition where H is turned off, H = 0, in which\nthe potential is\nk v^4,\nthe potential of the field in the on state will be:\nk (H^2 - v^2)^2 - k v^4\n= k H^4 - 2kv^2 H^2.\n\nThe minimum value, of course, is given by H^2 = v^2. So, it\nfluctuates around the value v, taking on the form\nH = v U chi\nwhere U is a unitary matrix and chi a (arbitrarily chosen) unit\nvector.\n\nAll of this should bother people, because General Relativity says\nthat mass is gravitational charge. If the Higgs is producing mass,\nthen isn\'t it also directly linked to the gravitational field?\n\nIn fact, you can answer this in part, by looking at how the Higgs\nwould act if the world were classical instead of quantum theoretic.\n\nMore interesting is what the Higgs mechanism would look like for\nclassical point particles. In this case, the Lagrangian has the\nform:\nL = m/2 v^2 = m/2 sum (g_{ij} u^i u^j\nwhere\nu^i = d(x^i)/dt\ni = 0,1,2,3\nt = proper time\ng_{ij} = spacetime metric.\n(Which, in fact, yields the geodesic law of motion in a\ngeneral relativistic context).\n\nInterestingly, also, this Lagrangian breaks down when the particle\nis massless -- even though its equations of motion reduce to those\nfor a massless particle, when the limit m -&gt; 0 is taken of them.\n\nBut if one starts out assuming, as above, that mass is dynamically\ngenerated by the Higgs, you\'re starting with massless particles.\n\nUsing the prescription outlined above, the mass is treated as\nthe field, itself, up to a coupling constant. So, it is replaced\nby a coupling constant g = (m/v) multiplied by the field H:\nL = 1/2 g sum (H g_{ij} u^i u^j)\n= 1/2 g sum (H_{ij} u^i u^j)\nwhere\nH_{ij}(x) = H(x) g_{ij}(x).\n\nBasically, what this does is introduce an extra degree of symmetry:\nscale symmetry. So, the Higgs field can be thought of as the\nscale part of a scale-invariant metric, the metric g_{ij} being\nthe rest of the metric, and the potential k(H^2 - v^2)^2 forcing\nH to remain in a permanently turned on state around the value\nH = v; thus breaking scale symmetry.\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>"Hatim Hegab" <htm_00@hotmail.com> wrote:
It's a way of explaining away mass dynamically. So the "m"'s
[itex]k (H^2 - v^2)^2[/itex].
Relative to the condition where H is turned off, [itex]H = 0,[/itex] in which
the potential is
[itex]k v^4,[/itex]
[itex]k (H^2 - v^2)^2 - k v^4= k H^4 - 2kv^2 H^2[/itex].
The minimum value, of course, is given by [itex]H^2 = v^2[/itex]. So, it
[itex]H = v U \chi[/itex]
where U is a unitary matrix and [itex]\chi a[/itex] (arbitrarily chosen) unit
vector.
then isn't it also directly linked to the gravitational field?
form:
[itex]L = m/2 v^2 = m/2[/itex] sum [itex](g_{ij} u^i u^j[/itex]
where
[itex]u^i = d(x^i)/dti = 0,1,2,3[/itex]
t = proper time
[itex]g_{ij} =[/itex] spacetime metric.
for a massless particle, when the limit [itex]m ->[/itex] is taken of them.
generated by the Higgs, you're starting with massless particles.
by a coupling constant [itex]g = (m/v)[/itex] multiplied by the field H:
[itex]L = 1/2 g[/itex] sum [itex](H g_{ij} u^i u^j)= 1/2 g[/itex] sum [itex](H_{ij} u^i u^j)[/itex]
where
[itex]H_{ij}(x) = H(x) g_{ij}(x)[/itex].
scale part of a scale-invariant metric, the metric [itex]g_{ij}[/itex] being
the rest of the metric, and the potential [itex]k(H^2 - v^2)^2[/itex] forcing
[itex]H = v;[/itex] thus breaking scale symmetry.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
May12-04, 05:05 AM   #2
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\nwhopkins@csd.uwm.edu (Alfred Einstead) writes:\n\n&gt; All of this should bother people, because General Relativity says\n&gt; that mass is gravitational charge.\n\nThis is _not_ what GR says. GR says that energy and momentum are the\nsource of gravity.\n\n&gt; If the Higgs is producing mass,\n&gt; then isn\'t it also directly linked to the gravitational field?\n\nOnly as far as the Higgs field itself has energy and momentum.\n\n--\nEsa Peuha\nstudent of mathematics at the University of Helsinki\nhttp://www.helsinki.fi/~peuha/\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>whopkins@csd.uwm.edu (Alfred Einstead) writes:
source of gravity.
Esa Peuha
May14-04, 06:14 AM   #3
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\nEsa A E Peuha &lt;esa.peuha@helsinki.fi&gt; wrote:\n&gt; whopkins@csd.uwm.edu (Alfred Einstead) writes:\n&gt; &gt; All of this should bother people, because General Relativity says\n&gt; &gt; that mass is gravitational charge.\n&gt;\n&gt; This is [sic] _not_ what GR says. GR says that energy and momentum are\n&gt; the source of gravity.\n\nMore correctly, mass = gravitational charge is exactly what the Principle\nof Equivalence says, and that _therefore_ that energy and momentum are the\nsource of gravity.\n\n&gt; &gt; If the Higgs is producing mass,\n&gt; &gt; then isn\'t it also directly linked to the gravitational field?\n&gt;\n&gt; Only as far as the Higgs field itself has energy and momentum.\n\nNon-sequitur.\n\nThe question was posed as a sequey to what followed it, which\nalready resolved the matter.\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Esa A E Peuha <esa.peuha@helsinki.fi> wrote:
source of gravity.
Non-sequitur.
May17-04, 08:15 PM   #4
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>whopkins@csd.uwm.edu (Alfred Einstead) writes:\n\n&gt; More correctly, mass = gravitational charge is exactly what the Principle\n&gt; of Equivalence says, and that _therefore_ that energy and momentum are the\n&gt; source of gravity.\n\nThe Equvalence Principle says that inertial mass equals gravity-affected\nmass, but it says absolutely nothing about the relation between\ngravity-affected mass and gravity-generating mass (and it had better\nnot, since there isn\'t any gravity-generating mass in GR). Anyway, you\ncan\'t possibly hope to derive the fact that the electromagnetic field\ngenerates gravity from that argument, since photons are massless.\n\n--\nEsa Peuha\nstudent of mathematics at the University of Helsinki\nhttp://www.helsinki.fi/~peuha/\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>whopkins@csd.uwm.edu (Alfred Einstead) writes:
> source of gravity.
not, since there isn't any gravity-generating mass in GR). Anyway, you
can't possibly hope to derive the fact that the electromagnetic field
Esa Peuha
May18-04, 03:44 PM   #5
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>"Esa A E Peuha" &lt;esa.peuha@helsinki.fi&gt; wrote in message\nnews:86p3c5zctts.fsf@sirppi.helsinki.fi...\n&gt;\n&gt;\n&gt; The Equvalence Principle says that inertial mass equals gravity-affected\n&gt; mass, but it says absolutely nothing about the relation between\n&gt; gravity-affected mass and gravity-generating mass (and it had better\n&gt; not, since there isn\'t any gravity-generating mass in GR). Anyway, you\n&gt; can\'t possibly hope to derive the fact that the electromagnetic field\n&gt; generates gravity from that argument, since photons are massless.\n&gt;\nBut photons are (at least from one viewpoint) localized energy and\nenergy gravitates too,\n\nNorm\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>"Esa A E Peuha" <esa.peuha@helsinki.fi> wrote in message
Norm
Thread Closed
Thread Tools
Similar Threads for: Re: Higgs Particles & Scale-Invariant Metrics & Breaking Scale Symmetry
Thread Forum Replies
On spontaneous symmetry breaking and Higgs’s mechanism of mass production High Energy, Nuclear, Particle Physics 12
If SUSY explains E-w scale breaking, does it require a little Higgs at Tevatron energ Beyond the Standard Model 1
Electroweak symmetry breaking without a Higgs High Energy, Nuclear, Particle Physics 3
Is Quantum Mechanics Scale Invariant? Quantum Physics 12
compactification scale versus decompactification scale Beyond the Standard Model 0
