Wave Physics: Understanding Harmonics for Communication Technology
  • Context: Undergrad
  • Thread starter Thread starter Rockazella
    Waves
The discussion centers on the concept of harmonics in wave physics and their significance in communication technology. Participants explore the definition of harmonics, their applications, and implications in both musical contexts and electronic communications.
  • Some participants define harmonics as multiples of a given frequency, citing examples like 440 Hz, 880 Hz, etc., and note their historical roots in ancient Greek philosophy.
  • Others argue that while harmonics are essential in musical instruments for creating unique sounds, they are generally undesirable in communication technology due to their potential to introduce noise.
  • One participant suggests that harmonics can be utilized in frequency multiplication through non-linear devices, such as diodes, which generate harmonics when processing signals.
  • A later reply questions the role of diodes in generating harmonics, seeking clarification on their non-linear characteristics and the implications for signal processing.
  • Another participant explains that any periodic signal that is not a sine wave can be expressed as a sum of a fundamental sine wave and its harmonics, referencing Fourier transforms.
  • Participants discuss the challenges of filtering harmonics in communication systems, noting that high-frequency harmonics can complicate the reproduction of original signals.
  • One participant raises a question about how a single instrument can produce a set of frequencies, suggesting a misunderstanding of molecular vibrations and their relation to harmonics.
There is no consensus on the role of harmonics in communication technology; while some participants view them as primarily problematic, others highlight potential beneficial applications. The discussion remains unresolved regarding the specifics of how harmonics function in various contexts.
Participants express varying levels of understanding regarding the technical aspects of harmonics, non-linear devices, and Fourier analysis. Some statements reflect assumptions about the nature of sound and signal processing that may not be universally accepted.
Rockazella
I've read the definition before, but I didnt really get the significance of a harmonic. I would like to know how they are used in communication technology. Anyone know wave physics well and wouldn't mind helping me out?
Harmonics
are just multiples of a given frequency. Just like 440, 880, 1320, 1760. At least that is the usual definition. The same for both sound and electric waves.
And the notion of a harmonic goes back to the ancient Greeks such as Plato and Pythagorus.
You can learn a lot about harmonics under Fourier Series.
with regard to communications
Harmonics are generally unwelcome and efforts are made to filter them out.
Harmonics are the essence of the variation between of musical instruments. What is the difference between the sound of a middle C played on a piano as compared to a flute; or a guitar compared to a tuba, or to a human voice, or to a bird? To a large degree the answer is harmonics. Each instrument can produce a middle C, but each produces its own unique set of harmonics that create the characteristic sound.
Edit: just as an analog for understanding. Of course with communications, harmonics are generally bad. Note however that harmonics can be used to produce desired results also. For example, I can build an oscillator circuit tuned to the 5th harmonic of a switching device; this can effectively yield an oscillator with a frequency 5 times greater than the switching device. Also, in large industrial applications, power networks are tuned so that the harmonics between two large inductive loads will cancel.
With the help of harmonics you could do a frequency multiplier. You take a signal at n Hz, pass it through a non-linear device (...a diode) and the resulting signal has a lot of harmonics. Then filter only the one you need (let's say the one at 3n Hz). And you have a multiplier by 3...
Guybrush
what do you mean by a non-linear device? You say a diode is an example, but what makes it that?
For example the resistor is a linear electronic device. If you make a plot that represents the current through the resistor vs. the voltage drop you get a line. This is the Ohm's law u = Ri .
If you make the same plot for a diode (called diode's characteristic) you don't get a line (look at http://www.americanmicrosemi.com/tutorials/diode.htm or this ). That's because the relation between u and i is no longer linear for the diode. Of course for some applications you can approximate the diode's characteristic as linear by working in a certain range of i, but that is not the case for the frequency multiplier.
A diode would clip an alternating signal... why would a diode set up harmonics?
If you do a Fourier transform on the clipped signal, you'll get a lot of harmonics...
(http://www4.ncsu.edu/~mowat/H&M_WebSite/FFT/fft.html)
Basically any periodic signal that is not a sine wave is a sum of a fundamental sine wave an harmonics of the fundamental.
Hey, that's a neat page!
How can one instrument at a given time produce a 'set' of frequencies, or harmonics?
molecules can't vibrate at more than one frequency at a given time, right?
Lets summarize what has been said so far.
If we have some pure sine wave of frequency K it has harmonics with frequency nK, for example if K=100Hz its second harmonic is n=2 so 2K= 200Hz.. Here K is the FUNDAMENTAL each multiple is a harmonic of that wave.
It is interesting that ANY periodic waveform can be expressed as a sum of harmonic sine waves. This is called the Fourier Expansion. For example
f(x) = 4(Σ Sin(nπx/L)/n)/π
Where the sum is over all ODD integers.
http://home.attbi.com/~rossgr1/Fourier1.PDF Is a graph of the fundamental, the 3rd harmonic and their sum.
http://home.attbi.com/~rossgr1/Fourier2.pdf
http://home.attbi.com/~rossgr1/Fourier3.pdf
This shows that high frequency content is critical to form a good square wave. If your computer does not maintain this content the square waves that are essential to the operation of your system will degrade. Computer engineers must be aware of this in order to design a successfull computer.
In communications, harmoincs are generally undesirable, they can appear as noise at some stage of amplifiction. It can be very difficult to filter out such noise as frequently your underlying signal may contain meaningful content at that frequency. This is the difficulty of audio circiutry, to accuratly reproduce and maintain fidelity of the original signal, any device that creates a sharp change in the signal (non linear) will produce high frequency harmonics. As again you must have high frequency components to create a corner.
Now as a final thought, consider your eardrum. How are you able to discern discrete instruments, or voices when it is a single small disk of tissue which is creating all the vibrations.
This question has the same answer as your question, and is related to Fourier analysis and something called the superpostion principle. (do a web search on that to see what turns up)
the four strings of mourning
  • · Replies 58 ·
9K
10K
