| Thread Closed |
Four Clocks Problem |
Share Thread |
| Sep6-08, 10:31 PM | #18 |
Four Clocks ProblemStep 2: Use only 1 scale for this measurement: Place on the scale B1+W1+Rheavy If the reading on the scale is greater than malpha then B1 and W1 are both heavy while B2 and W2 are both light. There are no ways to measure absolute value of malpa as suggested by you. Only six balls and a balance with two pans. No weights are available. |
| Sep6-08, 10:33 PM | #19 |
Please check . I am pasting ur solution. Step 2: Use only 1 scale for this measurement: Place on the scale B1+W1+Rheavy If the reading on the scale is greater than malpha then B1 and W1 are both heavy while B2 and W2 are both light. ............. Now There are no ways to measure absolute value of malpa as suggested by you. Only six balls and a balance with two pans. No weights are available. |
| Sep6-08, 10:40 PM | #20 |
OK, so it is a balance scale, and not necessarily a weighing scale.
Alright, I'll have to look at it again then.... |
| Sep7-08, 12:43 AM | #21 |
There is only one balance scale with two pans. No weights available. You can use scale twice only. Please excuse me if language of my question created any confusion. |
| Sep7-08, 09:24 AM | #22 |
Language, not a problem....
Mathematics is the universal language, right? |
| Sep8-08, 11:37 PM | #23 |
Btw, here's my take on the christmas tree problem... Let the blue, red and white balls be labelled A, B, C, respectively. Weigh A1+B1 against A2+C1. If A1+B1 == A2+C1, weigh A1 versus A2. If A1 > A2, then the heavier balls are A1, B2 and C1; otherwise, it is A2, B1 and C2. If A1+B1 > A2+C1, weigh A1+A2 against B1+C1 next. If A1+A2 > B1+C1, then the heavier balls are A1, B2, C2; if A1+A2 < B1+C1, the heavier balls are A1, B1, C1; otherwise, if A1+A2 == B1+C1, the heavier balls are A1, B1, C2. If, in the first step, A1+B1 < A2+C1, weigh A1+A2 against B1+C1 next. If A1+A2 > B1+C1, then the heavier balls are A2, B2, C2; if A1+A2 < B1+C1, the heavier balls are A2, B1, C1; otherwise, if A1+A2 == B1+C1, the heavier balls are A2, B2, C1. |
| Thread Closed |
| Tags |
| brainteaser |
Similar Threads for: Four Clocks Problem
| GPS clocks | Special & General Relativity | 27 | ||
| Clocks and vectors | Introductory Physics Homework | 1 | ||
| Atomic clocks / Dynamic clocks? | General Discussion | 8 | ||
| clocks | General Math | 8 | ||
| The clocks | Forum Feedback & Announcements | 1 | ||
