Register to reply
Gravitational influence?
by Holocene
Tags: gravitational, influence
Share this thread:
Holocene
#1
Aug31-08, 10:19 PM
Holocene's Avatar
P: 231
Suppose for a senond that the only objects in the entire univesre are 2 stars, both about as massive as the sun.
Also, this univesre is completely static. It is not expanding.
The stars, at least initially, are not moving relative to each other.
Under these conditions, about how much distance would need to be between the stars so as to ensure that they never collide?
Or does gravitational influence never deminish to zero, no matter how far away you get?
Phys.Org News Partner Astronomy news on Phys.org
A new approach in the search for extraterrestrial intelligence: targeting alien polluters
Lives and deaths of sibling stars
Australian researchers pioneer a 'Google street view' of galaxies
granpa
#2
Sep1-08, 12:10 AM
P: 2,258
gravity=1/d^2
it equals zero at infinity
Holocene
#3
Sep1-08, 01:02 AM
Holocene's Avatar
P: 231
Quote Quote by granpa View Post
gravity=1/d^2
So 2 grains of sand, 50 Billion light years apart, will eventually collide, even under static conditions?
That is pretty interesting when you think about it.
Oberst Villa
#4
Sep2-08, 02:35 PM
P: 145
Quote Quote by Holocene View Post
Thinking of all this Pioneer Anomaly and MOND mumbo jumbo, I would not bet my life that the equation given by granpa is really correct under such extreme conditions as you specified. A few decades later we may be smarter - or maybe not... All we can say now is yes, there is wide agreement that the 1/r^2 relation is correct and yes, the 2 grains of sand will eventually collide (but don't hold your breath for it....)
DaveC426913
#5
Sep2-08, 03:04 PM
DaveC426913's Avatar
P: 15,319
Quote Quote by Oberst Villa View Post
Well, 1] even if there is any substance to the Pioneer anomaly, then they still will collide. At worst, we might have the delay wrong.
2] It will take more than one anomaly to overturn centuries of verification and countless confirming experiment after countless confirming experiment of gravity's effect.
granpa
#6
Sep2-08, 03:13 PM
P: 2,258
yes, its actually very interesting. the gravitational field presumably like all fields is quantized both spatially and in intensity (I think thats called second quantization or something more or less like that) so what happens when the gravitational field from a particle diminishes to the level of one quanta?
joris20
#7
Sep7-08, 11:39 AM
P: 5
unless you define static conditions for me, i guess those grains of sand would just explode because theyre in a vacuum... or am i wrong here?
DaveC426913
#8
Sep7-08, 01:05 PM
P: 15,319
Quote Quote by joris20 View Post
Grains of sand explode in vacuum?? Awesome!
MeJennifer
#9
Sep7-08, 01:37 PM
P: 2,043
I have a hard-time seeing how this configuration is a valid GR solution.
tony873004
#10
Sep7-08, 01:39 PM
Sci Advisor
PF Gold
P: 1,542
The amount of time will be
[tex]t \approx 2\pi\sqrt{\frac{(0.5 d)^{3}}{G(m_{1}+m_{2})}}[/tex]
where d is the distance that separates them, and m1 and m2 are their masses.
Count Iblis
#11
Sep7-08, 01:55 PM
P: 2,158
If the grains of sand have a small angular velocity relative to each other, they'll miss. The farther away they are relative to each other, the smaller that angular velocity can be for the grains to hit each other. Now, the initial state will be some so-called coherent state in which the initial position is described by some wavefunction that corresponds to both position and momentum being in some small uncertainty interval.
So, you can simply use the uncertainty relation to estimate the maximum distance beyond which it becomes impossible to let the grains hit each other with reasonable probability.
joris20
#12
Sep8-08, 09:18 AM
P: 5
but even if they mis they could re-attract eachother and have a "second chance"
etc. etc.
DaveC426913
#13
Sep8-08, 03:58 PM
P: 15,319
etc. etc.
No. They are in orbit. If they didn't collide on the first pass, they never will. There's nothing to change their paths from the orbit.
In fact, one orbit will bring them back to their initial starting point, 50Gly apart and stopped wrt each other.
BTW, this whole problem makes the assumption that the universe is of infinite age (which, I guess, if there are only two particles in it, is pretty much a given) because these passes will take longer than our current universe's likely age.
MeJennifer
#14
Sep8-08, 04:01 PM
P: 2,043
Quote Quote by DaveC426913 View Post
That is simply not true under general relativity. The orbit will decay slowly.
Oberst Villa
#15
Sep8-08, 04:17 PM
P: 145
Quote Quote by MeJennifer View Post
Yes, but really really really slowly. They will only come close to each other every [too lazy to put the numbers in tony873004's equation] billion years, and even during this short encounter the loss of energy due to gravitational radiation will be soooooo tiny.
joris20
#16
Sep9-08, 10:10 AM
P: 5
well were tqlking about 'in the end' so technically, we have eternity which seems long enough :p
Count Iblis
#17
Sep9-08, 11:31 AM
P: 2,158
Take two grains of sand a distance of r (say about 50 billion lightyears) apart at rest. The mass of a grain of sand is m
(say 10^-6 Kg) . The potential energy is:
E = G m^2/r
For the system to be in a bound state, the momentum of the grains must not exceed P, given by:
P^2/m = G m^2/r ----------->
P = Sqrt[G m^3/r]
If the intital state is given by some wavepacket then in momentum space the spread must be significantly less than P. The uncertainty relation then gives a spread of the wavefunction in configuration space of:
Delta X = hbar/2 Sqrt[r/(G m^3)]
This is about 140 nm for the two dust grains placed 50 billion lightyears apart. I don't think it is realistic to assume that this wavefunction won't decohere into a statistical mixture of wavefunctions with much sharper defined positions.
Register to reply
Related Discussions
Influence of gravitational force on earth Introductory Physics Homework 21
Influence of L1 L2 etc Astronomy & Astrophysics 2
Did your parents influence your education Academic Guidance 12
The influence of mathematics General Discussion 6
