A voltage booster without capacitor
  • Thread starter Thread starter Truthlover
    Capacitor Voltage
The discussion revolves around the feasibility of boosting a 1.5V battery to 5V without using a capacitor in the circuit. Participants explore various aspects of boost converter topology, potential applications, and constraints related to the absence of capacitors.
  • Some participants inquire about the possibility of achieving 5V from a 1.5V battery without any capacitors, expressing a specific constraint against using them.
  • One participant mentions the need to power a 4.8V DC motor for a small car, raising questions about the implications of running the motor at lower voltages.
  • Another participant suggests using a boost converter and refers to design tools available from National Semiconductor, emphasizing the importance of efficiency and battery characteristics.
  • Some participants discuss the role of capacitors in boost converters, questioning what happens if the output capacitor is omitted and the effects of varying capacitor sizes.
  • A participant proposes that the challenge may involve using alternative components, such as inductors, to achieve the desired voltage without capacitors.
  • There is a suggestion that the task may involve generating a pulse waveform to drive the motor, which could be a non-standard solution to the problem posed.
  • One participant raises the possibility of running the motor directly from the 1.5V battery, although this would result in lower performance.
Participants express differing views on the feasibility of achieving the voltage boost without capacitors, with some exploring alternative methods while others question the constraints of the challenge. The discussion remains unresolved regarding the best approach to meet the specified requirements.
Participants mention various assumptions regarding the operation of boost converters, the role of capacitors, and the characteristics of different battery types. There is uncertainty about the implications of omitting capacitors and the specific requirements of the challenge.
Truthlover
Hello i just want to know if it's possible to do 5V with a 1.5V battery without any capacitor
Thanks
Thanks
Are you familiar with the boost topology DC-DC? Why do you not want an output smoothing cap? What is the application that you have in mind?
I have to run a 4.8V DC motor with a 1.5V battery. The motor is used to propulse a little car.
Look at the Simple Switcher boost DC-DC circuits at National Semiconductor:
http://www.national.com/analog
Click on the design helper at the right of the page, and input your voltage and current requirements. The calculator will help you design the circuit. You can generally buy the parts from Digikey.com
You should also calculate how long the motor will run on that 1.5V battery. Assume about 85% efficiency for the boost stage (the National calculator may guesstimate the efficiency for you -- I'm not sure if it will), and check the A*Hr rating of the 1.5V battery. BTW, when you spec the input voltages for the calcultor, keep in mind that the range for an alkaline battery is about 1.65V fresh, and 0.8V mostly gone. Other battery types will have different discharge curves. Check the battery manufacturer websites for datasheets.
I think the calculator will provide you with an output capacitor value. I'm still not sure why you don't want to have a cap at the output. If you still have questions after using the calculator, post them here and we'll try to help.
This is very good but i want to know if it's possible tu use the booster without capacitor. it's a constraint.
In example: is it possible to use this boost converter without the cpacitor if not what will happen
You tell us. What is the function of the capacitor in the standard boost DC-DC converter circuit? What happens as you make the capacitor larger, or smaller?
There are at least two effects of decreasing the output capacitor size. Can you tell us what they are?
Why do you have this constraint? Is it coming from someone who does not have an understanding of electronics? Or is it being posed as an advanced puzzle by someone who knows of an elegant non-standard solution?
it is posed as an advanced puzzle by someone who knows of an elegant non-standard solution. It's like a challenge. so i have to find a way to do 5V with a 1.5V battery without any capacitor.
You'll need some kind of reactance, but it doesn't have to be capacitance. You can build a voltage multiplier with inductors, too -- they're just larger and heavier and more expensive.
- Warren
Couldnt you just run the motor with a 1.5v battery instead? You would get lower rpm's and power, but it would still work right? And isn't this http://en.wikipedia.org/wiki/Image:B...onventions.svg circuit a half wave rectifier?
Is the puzzle saying to run a 5V DC motor, or is it saying to get 5 Vdc?
That link does not work.
Thank you chroot for your advice it worked. And yes chaoseverlasting i could run the motor with 1.5v but it was also a question of speed.
You cannot use an actual capacitor or you can't have any appreciable capacitance in the circuit? I ask because you can be clever and use some coax as some capacitance in the circuit.
'Puzzle', 'non-standard', and 'challenge', and the fact that you have specifically not specified 'DC', just 5 V, lead me to believe that your tasker intended some kind of pulse waveform be used which is plausible w/ a motor load. You can drive the motor with some kind of 5V pulse waveform. The DC/DC boost converter (referenced above) with no output capacitor with give you a pulse waveform, and the duty cycle of the converter would control the motor speed.
  • · Replies 32 ·
  • · Replies 78 ·
  • · Replies 49 ·
  • · Replies 19 ·
