Is Arrowed Nitrogen in Organic Compounds Acidic or Basic?
The discussion centers on the acidity and basicity of arrowed nitrogen in organic compounds, specifically within the context of secondary amines. The consensus is that the nitrogen is a weaker base due to the resonance effect from an adjacent oxygen atom, which influences its protonation behavior. The initial confusion regarding the nitrogen's classification as acidic is clarified, confirming it is not acidic but rather a weaker base.
  • Understanding of organic chemistry concepts, particularly amines
  • Knowledge of resonance effects in molecular structures
  • Familiarity with acid-base theory in organic compounds
  • Basic skills in interpreting chemical structures and functional groups
  • Study the properties of secondary amines and their behavior in acid-base reactions
  • Research resonance structures and their impact on molecular acidity and basicity
  • Explore the concept of weaker bases in organic chemistry
  • Learn about the role of electronegative atoms, such as oxygen, in influencing nitrogen's properties
Chemistry students, organic chemists, and educators seeking to deepen their understanding of acid-base behavior in organic compounds.
PascalPanther
I'm trying to determine whether the arrowed nitrogen is acidic or basic. Apparently the answer is that it is acidic. I don't really understand how I am suppose to make that call. That nitrogen is part of secondary amine that is basic, with resonance effect from the oxygen that will make it more acidic. However, how do I know that the oxygen has enough effect to make it acidic and not just a very weak base?
Edit: Ahh... read the answer wrong. It didn't say it was acidic, just that it was indeed a weaker base.
Problem solved.
PascalPanther said:
Problem solved.
  • · Replies 18 ·
  • · Replies 19 ·
11K
