Shearing stress - timber truss
The discussion revolves around determining the dimension 'a' for member AD of a timber truss, ensuring that the average shearing stress parallel to the grain at the ends of the chord ABC does not exceed 2.25 MPa. The context includes homework-related queries, free body diagrams, and the method of joints.
  • Homework-related
  • One participant questions the correctness of their free body diagram and seeks confirmation on whether to solve for forces using the method of joints.
  • Another participant points out an error in the free body diagram, stating that there should be no horizontal external force at pin A and emphasizes the need to determine vertical reactions first.
  • Several participants discuss the approach to calculating tensile forces in the bottom chord, with some suggesting treating it as two segments while others argue that the tension is the same across both segments.
  • There is a mention of the average shearing stress being influenced by the angle of the member, with some participants unsure if they need to deduce this angle from the reactions.
  • One participant provides calculated values for reactions and forces, arriving at a dimension for 'a' of 80mm, while another participant suggests that the correct dimension should be 53.3mm, indicating a discrepancy in their calculations.
  • Further discussion reveals confusion regarding the calculation of angles and the correct application of shear area in the shearing stress formula.
Participants express differing views on the correctness of free body diagrams, the method of calculating forces, and the resulting dimension for 'a'. There is no consensus on the correct approach or final value for 'a', indicating multiple competing views remain.
Participants note limitations in their calculations, including potential errors in determining angles and the interpretation of shear area, which may affect the final results.
Students and professionals interested in structural engineering, particularly those dealing with timber trusses and shear stress calculations.
portofino
member AD of the timber truss shown (attached) is framed into the 100 X 50 -mm bottom chord ABC as shown (attached - detailed view). determine the dimension 'a' that must be used if the average shearing stress parallel to the grain at the ends of the chord ABC is not to exceed 2.25 MPa
shearing stress, tau = V/A where V is shear force, A is cross sectional area --> average
is my free body diagram correct? if so, do i first solve for the forces in each member using the method of joints. do i consider that the chord in question is also the same at where the roller is located?
once i have found all the forces in each member based on the free body diagram do i just use what i found to be the force at C as the value for V in the shearing stress formula? do i then just solve for A aka 'a'?
please tell me if i am on the right track, if not, any assistance appreciated
Your FBD is not correct. There can be no horizontal external A_x force at the pin A, because there are no other external forces in that direction to balance it. The reaction loads at supports A and C are both vertical only. Determine what they are, and solve for the tensile force in the bottom chord. The shear plane is not the cross section area of the lower chord, it is the plane parallel to the grain of length 'a' and 50mm in width. Your figure is a bit confusing, I think the chord is 100mm deep and 50mm into the page (a 100 X 50mm timber).
when i solve for the tensile force in the bottom chord, is the best way to do this is:
- treat the bottom chord as the sum of the two 2m pieces
is the average shearing stress a component of an angle, there is none given or am i meant to deduce the angle from finding out the reactions etc?
- treat the bottom chord as the sum of the two 2m pieces --> find reactions/tensile in each 2m portion and then sum them
No, whether they are 2 pieces or one piece does not matter. They do not add. The tension in AB is the same as the tension in BC. If you isolate joint B, you should see that in the x direction, the tension in AB must be equal to the tension in BC (AB tension points left, BC tension points right). But first, in order to arrive at that tension value, you should determine the vertical reactions and then isolate joint A and solve for the member forces at that joint using the method of joints. Have you determined the vertical reactions? Are you familiar with the method of joints? Note it is given that member AD has a slope of 1.5/2.
This problem is a bit tricky, in that usually in a pure truss one deals with axial tension or compression forces only. In this case, you have a tensile force in AB due to the horizontal component of AD, that is pushing the member AB outward (to the left). That introduces a longitudinal shear in the wood timber over the length 'a' and 50mm width, trying to split and tear the wood apart in shear across that plane. To calculate the distance 'a', note that the shear stress is equal to the tensile force in AB divided by the shear plane area, that is parallel to the load, of (.050)(a).
after checking the solutions, the dimension for a should be 53.3mm, i am getting 80mm.
after doing the method of joints here are my values for the reactions
F_BA = F_BC = 9kN
F_BD = 18kN
F_DA = F_DC = F_CD = 12kN
Cy = Ay = -7.94kN
see attachment for corrected free body diagram and angles calculated from given dimensions
ultimately solving for a using tau = V/A
2.25MPa = 9kN/0.05a --> a = 0.08m = 80mm
F_BA = F_BC = 9kN
F_BD = 18kN
Cy = Ay = -7.94kN
A few comments. Your calculation for theta is wrong, you used the sine function when you should have used the tangent. But beyond that, your member forces and reactions are incorrect in any case, except for F_BD. The vertical reactions at Cy and Ay must add to 18, per Newton 1, so I don't know how you got -7.94 instead of +9(upward load on the joint). Make that correction, then isolate joint A. The 9kN vert load must be balanced by a 9kN vert component downward in AD. The 9kN vert component in AD implies a horizontal component of 12 kN in AD {(2/1.5)(9) = 12}. So what must be the tension in AB? (And BTW, when I do the calculation for a, I get a value of 106.6mm, which is twice the book answer, so it appears that they are using a shear area of .1(a) instead of .5(a), maybe I'm misreading your sketch which is unclear as to what is the depth and what is the width of the bottom chord).
this exact problem was given to us as an assignment.
from what book did you get this problem? thnx
10K
13K
