Register to reply
How do I find the necessary height for a shot tower in this problem?
by Lida
Tags: height, shot, tower
Share this thread:
Lida
#1
Sep4-08, 07:18 PM
P: 10
Ball bearings can be made by leting shperical drops of molten metal fall inside a tall tower - called a shot tower- and solidify as they fall.
If a bearing needs 4.0s to solidify enough for impact, how high must the tower be?
What is the bearing's impact velocity?
I've never taken a physics course before. I have no idea how to figure out the height of the shot tower, I think I'm supposed to know from the 4 seconds that the tower is a certain height, but I'm totally clueless. If someone could even just tell me how to figure that out I'd really appreciate it.
I saw an old post with a near identical question from 2 years ago, but looking at the answer given there didn't help me figure out what to do here.
Help??
Phys.Org News Partner Science news on Phys.org
NASA team lays plans to observe new worlds
IHEP in China has ambitions for Higgs factory
Spinach could lead to alternative energy more powerful than Popeye
Hootenanny
#2
Sep4-08, 07:29 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,781
Quote Quote by Lida View Post
Help??
Welcome to PF Lida,
What is the acceleration of the shot?
Lida
#3
Sep4-08, 08:03 PM
P: 10
Quote Quote by Hootenanny View Post
Welcome to PF Lida,
I dooooon't knooooow! :(
Should it be obvious from the problem? I'm so confused by this.
And thanks for the welcome. :)
Hootenanny
#4
Sep4-08, 08:06 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,781
No problem, I see from your initial post that this is your first physics class, do you have a class text? Have you come across kinematic (SUVAT) equations before?
Lida
#5
Sep4-08, 08:37 PM
P: 10
Ok. I have a book called "How to Solve Physics Problems" and it uses 9.8 a lot for free falling objects, so I'm guessing that might be the acceleration of a falling object?
If that's the case, then the shot tower is 39.2 m right?
And I got that the velocity was 9.8 m/s, but I'm not so sure about that. Is it right?
Thanks!
Hootenanny
#6
Sep4-08, 08:40 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,781
Correct. 9.8 m/s2 is the acceleration due to gravity or the acceleration of an object in freefall.
Not quite, perhaps if you detailed you calculations we could point out where you're going wrong.
chislam
#7
Sep4-08, 08:42 PM
P: 79
Thanks!
No, that's incorrect. Use this equation, and solve for y (height). Make sure that you plug in your known variables: a (acceleration), t (time).
[tex]y = \frac{1}{2}at^2[/tex]
Lida
#8
Sep4-08, 08:50 PM
P: 10
Quote Quote by chislam View Post
With this formula I got 192.08m for the tower and 48.02m/s for my velocity. Closer?
Lida
#9
Sep4-08, 08:52 PM
P: 10
I multiplied 9.8 by 4 in an attempt to reverse the equation for acceleration.
Hootenanny
#10
Sep4-08, 08:56 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,781
I'm afraid it's still incorrect. Have you tried looking in your text for kinematic (SUVAT) equations? A summary of these equations can be found here.
Lida
#11
Sep4-08, 09:19 PM
P: 10
Now I figured 39.2 as my velocity and got 348.88 for the tower. This doesn't seem right, but I did that using the x-x0= v0t + 1/2at^2 equation. ( I'm using 192.08 for 1/2at^2)
Using 19.6 instead of 192.08, because I think that might be where I'm going wrong, I end up with 176.4.
Are either of my answers right?
How do I figure out the difference between x and x0?
Lida
#12
Sep4-08, 09:42 PM
P: 10
I think the answer is 78.4 now...hopefully.
Hootenanny
#13
Sep5-08, 02:14 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,781
Correct
Lida
#14
Sep5-08, 06:46 AM
P: 10
Finally!
Thanks!
Register to reply
Related Discussions
Find Maximum Height, Time, and Duration. Introductory Physics Homework 6
A projectile of mass 0.552 kg is shot from a cannon, at height 7 m,? Introductory Physics Homework 2
How to find the height where two same marbles have the same velocity? Introductory Physics Homework 15
Find the height of the water Engineering, Comp Sci, & Technology Homework 4
Finding the maximum height of an arrow shot in the air Introductory Physics Homework 3
